Caliper bleed screws / nipples
james944
Hi,
After refurbishing my rear slider calipers the bleed screws were seized in good and required replacing after their mutilation upon removal.
My cars an early (square dash) 1984 944 LUX. I'm trying to find replacements for the bleed screws but the only problem is I put the old bleed screws back in as I needed to move the car. Now I can't measure them.
Anyone have a link to specs or know what size the bleed screws would be. M7 x 1mm? But what length?
If you know front and rear and clutch salve specs too (unless they're all the same) that'd be great.
James
Hi, I recently bought M7x1mm- 38mm long as that was what was fitted to my callipers before I refurbished them. I had used shorter ones but I was concerned they were not seating properly and causing a spongy pedal. They were bought on EBay from a company called VW heritage.
