Controversial.
Coppergrease is not really a lubricant, but an anti seize compound, just like aluminium greases. Which is an important thing to keep in mind.
If two parts come together, and rearely are seperated, then coppergrease or alumiunium grease will stop them seizing up.
If two parts move against one another, ideally, you want a lubricating grease... But then brakes are a little different, because the movement is very slight and low load..
Wherever possible, you are also supposed to keep dissimilar metals apart, such as not having a steel screw going into an aluminium part.. But that is unavoidable, otherwise Porsche would have used aluminium bolts to hold the aluminium head onto the aluminium block.
So there is a lot of talk about not using copper grease on Porsche cars, and one of the reasons for this is that it is thought that using a copper grease on the aluminium wheel nuts of cars like the 944, will promote the degredation of the aluminium bolt.. So, you are supposed to use an aluminium grease, as an anti seize, in those situations.
There is also talk that you should not use any grease or petrolium based product on brakes, mainly because petrolium based products attack the rubber in seals, such as brake caliper dust boots and seals.. In which case, people like Brembo, who make the S2 and turbo calipers, would like you to use their special grease everywhere... which is just Silicone grease, as you can get from a plumbers merchants, which is a lubricant, not an anti seize.
There is also the argument that greases on brakes, could melt with heat, and migrate to friction linings, like brake pads..
So what can you draw from all this????
1. Use some common sense and do not use too much of whatever you use, wipe away excess and keep it off the rubber bits.
2. Use copper grease on single piston calipers where they slide (the caliper has 3 main parts), wipe away the excess.
3. Use aluminium grease on the wheel nuts
4. You should not need to use it on the backs of pads, but you can, just use the minimum you need
I have never seen a rubber boot that has degraded by any copper grease on it, or anyone use enough copper grease for it to end up on a friction lining.. I have seen a lot of wheel nuts that have oxidised so much they crumble, but would not know if copper grease had caused the oxidisation. However, common sense and a little precaution are free... New parts cost money... You pays your money and makes your choices
