Caliper refurb
- Thread starter rcsalmons
Dave Wilkinson
Dave
Frenchy
I cannot see how they would need to change the plates, they nip the pads when aluminum corrosion occurs underneath them from the caliper body pushing them on to the pad they should simply need cleaned, straightened if required and refitted, sorting the corrosion in the caliper should suffice to cure the problem.
As Alasdair has said is that labour only cost, let us know.
robwright
see here
robwright
944Scott
How long is reasonably soon Al ?
The caliper plates only break if there is a large build up of corrosion behind them, the caliper is usually scrap then anyway as the metal holding in the clip corrodes through.
Alasdair
