pacemaker1000
hi i am painting my corroded callipers next week while i change all four discs and pads.
car will be on axle stands ( have yet to find where they go after using the jacking point to lift in the first place) what is the best form of application?
spray will probably look better but will get everywhere whereas brushing is easy
also how many coats advice on paint and do you need lacquer as well, i read some paint does not need it.... if it does then you need to spray it anyway i assume.
thanks
thanks
