Cam Belt Auto Tensioner
- Thread starter barks944
ChasR
I think you can remove the plunger spring though to make it fully manual adjusting.
Ignore my post, I've figured out you probably knew this already (doh!).
ChasR
ChasR
Two of the bolts are meant to be quite accessible, but the other bolt is hindered by the 5th roller. and needs to be removed via feel.
Here is a more annotated version of Clarke's cambelt change guide from Rennlist:
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/488666-clarks-eng-05-belt-removal-procedure-updated-for-s2.html#post6382503
And a picture of the said autotensioner:
![autotensioner_roller.jpg](http://i273.photobucket.com/albums/jj237/ldeprat/autotensioner_roller.jpg)
On the RH tensioner you will see where the 3 bolts go so as to give you an idea.
