cam belt change interval 944 s2
Bronson
hi, could someone advise what the change interval is for the cam belt?.... is it time based and/or mileage. and is it possible to determine whether a change is required through a visual inspection?.....just bought a s2, cam belt was changed in dec 2008 @127k, 7k miles ago. not sure whether to change - not a cheap job as tempted to do water pump at same time, adding to the cost....
any advice would be most appreciated.
The general rule of thumb is 4 years or 40000 miles. I wouldn't rely on a visual inspection. If you can do the work yourself the belts are that cheap you would be stupid not to follow those guidelines. I am not sure if there is a specified interval for the cam chain and slipper pads but it would be worth looking at. People have had them fail and paid the price. I am not scaremongering but if I had bought an S2 then I would certainly check it out for piece of mind
You really MUST check the chain tensioner. The plastic pads get brittle with age and break. When I checked mine 100 miles after buying it, the tensioner top pad was cracked in half and holding on by a thread.
Unless you are very lucky (as I was), the broken bits get stuck in the sprockets and then you lose some combination of chain, cams, tensioner, valves and even the cylinder head casting itself.
It's a really easy job to check, you can pull the cam cover with just a good quality 5mm hex bit. It's possible to wiggle the cam cover away from under the fuel lines without removing them.
I would replace the tensioner plastic pads as a matter of course unless they have obviously just been done. That's a job you can do on the driveway, there are loads of instructions online. All I would say is use a torque wrench that goes down to 10nm and take your time... there are lots of reports of people stripping the threads in the head. I also changed the J-tube that feeds the tensioner, the crush washers and cam cover gasket. I probably should have changed the cam chain as well... but it looked OK and I didn't fancy taking the cams out.
If the car has done close to 130,000 miles and no evidance of cam chain being replaced I would do it. The part is 21 quid and it saves a whole heap of trouble
Mine wasn't and it broke took out the head and 1 cam as well
regards
Stephen
I already have the chain sitting on a shelf... I just haven't had the confidence to take the cams out yet!
Did your chain break spontaneously or was it a consequence of a tensioner failure? I've read conflicting advice... some say the chain only fails as a result of tensioner failure...
Chain seems to go as a result of the tensioner pad breaking but very high miles 200K ? the sprockets can wear which can lead to teeth breaking.
ORIGINAL: robdimond
Not sure to be honest it broke when i was starting the car, it never actually ran just sounded like it had no compression. but it was a sore one on the wallet.
use the search engine here, I am sure I later read 130,000 was the magic milage, mine had done 136,000.
good luck and enjoy the car
cheers for the advice guys. a no brainer needs to be done. so a little more advice please. what should be replaced given that im having it done.
so i have the following on the shopping list:
cam belt (of course :)
tensioner
idler for cambelt
balancer belt
idler & tensioner.
and i might just do the water pump whilst im at it. anything else?...any advice on where i could source the parts from at a decent price?
cheers
Do a search on here - there is a lot of info on belts and tensioners and water pumps.
That is the correct list of things to buy. Best price I found for them was from Promax Motorsport.
There's also a couple of oil seals on the front of the engine, only accessible when you have the front off to do the belts. When I had my 968 belts done last year, Cliff found 2 that needed replacing.
anyone had any experience or would recommend euro car parts - they've quoted all in incl the water pump, belts, tensionser, rollers etc £326 incl VAT.
the pump is lasso which i understand to be oem. but they could'nt confirm if the belts etc were oem - does it matter?
cheers
