cam belt tensioner
- Thread starter muzz
pauljmcnulty
Would specialists do this? I wonder how they'd work the small price they'd charge against any potential liability. Even if they weren't liable for any unexpected failure you can imagine the damage caused to them by "I had my belt checked by Blogg's Porsche, and 8 years later it broke. They refused to pay for a new engine, AVOID!! [][][]". As internet reviews tend to go.... [&o] Given that the tensioning tool is available for only the cost of postage as a PCGB member, or postage plus a charity donation as a Tipec member, why try to guess it? PCGB accept a charity donation as well. []You can also always fit new belts and then have them check by a specialist if you are unsure or don't trust your own judgement.
pauljmcnulty
Great, but surprising. Maybe I'm too paranoid! [&:] I thought my indie factored in a hour to check/retension belts. Whilst I understand that's a minimum-charge rate, and would probably take less, what would be a realistic time to book a car in, get it in the workshop, do the check/tension, reassemble, and do the invoice and payment?My local Porsche center would happily check my belt tension for me. The service manager knows it would take seconds to do
pauljmcnulty
Not at all, I think it's important to have that relationship with whoever works on your car, and that's my reasom for changing this year. I was no longer dealing with the people working on the car, nor the owners of the business, just their new middle-level people who were no use at all. No reason a main dealer can't be good at their job, or competitively priced! My point was whether a Porsche centre, or an indie, would risk getting involved with checking, and perhaps somehow endorsing, a DIY job. Great if they do, but it surprises me they would risk it. You might be a great client, but if you sell the car next week with "recent belts, checked by Porsche centre xxxxx", that opens them up to an argument down the line. Again, I think I'm being paranoid about it, and if you can get the belts checked locally then that's a plus for the diy-ers.Maybe I'm just lucky and have a rose tinted view of OPC's ,but I can't speak highly enough of my one.
I agree. Timing belts are timing belts, and a familiarity with the way such things work will mean you are able to do the ones on a 944 pretty easily. I suspect the hype about belt tension arose from the balance belt tension, which is very very loose. So loose it appears worrying the first time you see it. But - again - once you are familiar with it then you'll be fine. My local indie (Tower Porsche in Bermondsey) is happy to check belt tensions for free. If you take the car to him and take the covers off he'll give you the five minutes needed to check it and even set it right if you ask him nicely. Interestingly, he doesn't use a tension gauge but does it by hand, and by running the engine and watching how much the belts flap around (answer: quite a lot). Oli.ORIGINAL: colin944 The tensioner needs to be set. But once you know its ok then its not so hard.I personally think too many people get caught up in the hype about belt tension. Yes is is important but it's also common sense and if you have done a few timing belts in your life then you won't have any trouble doing your 944 belts.
Nice to see you back Oli [][]ORIGINAL: zcacogpI agree. Timing belts are timing belts, and a familiarity with the way such things work will mean you are able to do the ones on a 944 pretty easily. I suspect the hype about belt tension arose from the balance belt tension, which is very very loose. So loose it appears worrying the first time you see it. But - again - once you are familiar with it then you'll be fine. My local indie (Tower Porsche in Bermondsey) is happy to check belt tensions for free. If you take the car to him and take the covers off he'll give you the five minutes needed to check it and even set it right if you ask him nicely. Interestingly, he doesn't use a tension gauge but does it by hand, and by running the engine and watching how much the belts flap around (answer: quite a lot). Oli.ORIGINAL: colin944 The tensioner needs to be set. But once you know its ok then its not so hard.I personally think too many people get caught up in the hype about belt tension. Yes is is important but it's also common sense and if you have done a few timing belts in your life then you won't have any trouble doing your 944 belts.
Thanks Squire. Oli.ORIGINAL: colin944 Nice to see you back Oli [][]
pauljmcnulty
Happy to give an opinion as someone who's never tensioned a belt in his life. [&:] I'm sure that a "90 degree twist" is an accurate measurement if you do it every day. That's not a measurement that most amateurs would want to commit to, however, when there is a tool available for almost no cost that eliminates any doubt. It might be over-kill to worry about getting it right. But, if it only costs the postage for the tool, against the nagging doubt of a bust engine, what's the reason NOT to check it properly? [8|]A friend used the official tool through the club after fitting and tensioning belts, turns out the belt had 90 degrees movement on the longest section after setting, seems to be a lot of opinions on this ?
ChasR
Veerzigzag
Well if Paul hasn't done it, that's a very clear message to get it done by a specialist.....someone who's never tensioned a belt in his life
