Jinxy
Took my 944 2.7 into Porsche at Hatfield OPC a few weeks ago & they kindly lent me a 63 plate red Cayman 'S' with 6k miles on it whilst they carried out a Cam belt & Balance belt change for me ( That was fun !!
, it turns out I needed a new water pump as well & I had a slight oil leak from the front crank seal, so asked them to do it as they were reluctant to do the cam belt without changing the oil seal, picked the car up yesterday........ £1800.52 lighter !!!!! it took them 19.35 hours & labour was £825 !!, the parts needed were:-
1 x cam belt
1 x cam roller
1 x balance belt
1 x balance belt roller
2 x shaft sealing
2 x spacer sleeves
2 x gaskets
1 x crank seal
1 x round crank cr
1 x Alternator belt
1 x narrow v belt
1 x water pump
1 x gasket
8 x hexagon head bolts
2 x tensioning rollers
1 x packet of tyre valves that I needed for a friend.
That hurt, but at least the car had a thorough going over whilst it was there & I now know the belts & pump are good for a few thousand miles, the only report was a slight leak from the rear main crank seal, slight lateral play in the front struts, slight leak from the cam carrier gasket & play in the bottom steering U.J all that can be done over the next few months... just recovering now & nursing a battered credit card !
1 x cam belt
1 x cam roller
1 x balance belt
2 x shaft sealing
2 x spacer sleeves
2 x gaskets
1 x crank seal
1 x round crank cr
1 x Alternator belt
1 x narrow v belt
1 x water pump
1 x gasket
