912UK
Ok so I was reading and one of the main problems with the S2 ( well poss all 944's ) but only talking about the S2 here. Is this tensioner chain and the pads.. So It got me thinking what's mine like
So I took the top off... and this is the result of what i see..
your views please..
the pads look quite new. the wear is less than 1mm heck it's less than 1/2mm and they are not as brown as I expected with the oil and time.
The service history does show that the car has been serviced it does not say the words replaced tensioner.. but I can see an invoice for inspect and replace the chain for the more modern chain at about 58,000 and the car is on 89,000 by a company called 2 plus 2 limited...Looking to be in the Midlands area.. It also says about removing the cams to inspect the gears so I am guessing they have changed the pads when they did the chain as it looks so new..
So does this look nice and safe or should I chuck some money at it and get it all done??
pics here..
I feel more comforted by the thought some work has been carried out on the car in this problem area.. the cam belt has been changed and the tensioner..but not the water pump something I will do over winter..
your views please..
pics here..
