Cam chains
- Thread starter Nick Paul
chrishak
The 3.2 Carrera Sport had suspension and aero mods but nothing else as far as I am aware.
vitesse
Hans Renold invented the bush/roller chain & the British Standard was based on his designs,which combine the best balance of tensile strength,weight & bearing pin/bush areas to give suitable life with HP rating.
Overall life is determined by both component wear capability (which is dictated by case hardening depths on the pin/bush) & fatigue life & generally chains normally wear out before reaching their fatigue life-obviously steels used are slightly special & metallurgical advances plus control of tolerances have helped chains to keep up with engine power advances-it is becoming more common for camshaft drives to revert back to chain from belt as engine powers increase with smaller engines these days.
Yes ,you can increase strengths & this would cope with higher peak loads in camshaft drives but then the wear factor still restricts the life which is no good for road cars.
However on racing motorcycles,where all you want is a chain to last the race with certainty,then strengths are increased,rollers softened so they don't crack etc but then changed every race.
chrishak
WOW indeed. I said it would be an interesting thread!ORIGINAL: 911 targa
WOW
vitesse
Correct alignment is a requisite & with the correct sprocket tooth profile,wear equating to 2% can be accommodated but at this point ,the chain would be at its wear life as all case hardening will have been used up,but this would be expected to also mean engine life .
Of course 1 bad drive example is the cam to cam drive on the 16 valve 944/968 engines -very short centres coupled with small sprockets & the use of a connecting link which allows the link to alternately stretch/contract-bad for fatigue.
