colin smith
I noticed I have slight weep from the cam cover on the exhaust side, I think it's just the gasket. Is it a big job the remove the cover and replace it?
Sorry yes - those were the seals I meant. Well it was six months ago []ORIGINAL: elvis Wouldn't worry too much about the seals on the bolts, the bits I would change while you're at it are the big 'o' rings around the spark plug holes (928 104 443 08). If these don't seal then the spark plug recesses fill up with oil and you get misfires. Edit: 30 minute job, make sure you clean the allen key heads out as you don't want to round them and they can be a bit snug if it's not been done for a while.
