Hi,
I have the following fault code on my 996 c4 my2000
P0343
112 Camshaft Position Sensor 1 "" Above Limit
I removed the sensor and checked out using the diagnostic info and found that I read battery voltage on pin III/20 (pin 2 on sensor plug). The troubleshooting says short on the wire and points to wire damage but even disconnecting the wire from the dme and the dme pin reads battery voltage all the time.
Now I am stuck, looks like a DME internal fault or could other wiring external to the dme cause this reading?
Any help appreciated
Could the troubleshooting procedure be wrong as i thought dme's were very very reliable??
The car symptoms are, starts and drives ok but slow to rev over 3k ish. no CEL
P0343
