Cambelt change
Hi - i am considering buying a post 2003 996 with a higher than average mileage (to save money!)..
Can someone please tell me at what mileage/age a cambelt change is normally due on a 996? And how much would this cost at an OPC or independant?
Thanks in advance..
[:)] oh right...
so am i right in thinking the only servicing required is a minor/major service at 12k/24k respectively - or minor once a year if less than 12k AND spark plugs every 24k (- purely mileage dependant)?
is the only difference between a minor and major service the spark plugs?
thanks again.. as you can see i am a little naive & confused!!
Theres a poly rib belt that needs changing every 48K in the major service. I picked mine up today after 96K service from an indy and coughed just under the £1K mark albeit included a few other parts so probably about £900 ish.
ORIGINAL: NXI20
There's a 48K service also - they change the brake fluid on that one.
No they are independent of each other. I dont need brake fluid change until next year. The 48K service did include g'box (tip) oil change.
ORIGINAL: NIL98
Spotted my mistake after I posted - now corrected [:)]
