smiffyraf1
hi guys feel like im spending most of my life on here asking for advice now
started taking the cambox this weekend as the gasket has been leaking quite bad and thought id do the belts at the same time and found all of the bolts rediculously tight even with a breaker bar was a struggle and on one of the bolts under a plug at the top of the box the allen drive snapped in the head pretty much flush with the bolt. am pretty much stumped how to get this bolt out now, thought about hammering a socket down over it but because the plug hole is pretty small after grinding a 12mm down to get through am pretty sure it would crack when hammered. also thought about drilling allen bit out and if still not budging drilling the head of the bolt. and then thought as its the access thing thats a pain to just smash the cambox with a hammer and remove the bolt with loads of access and get a new box.
any thoughts or advice greatly appreciated
james
james
