camshaft bearing whine
Hi dudes,
Can anyone give me any advice, regarding camshaft bearing replacement _ whurring noise?
(944 2.5 8v 86)
laters n.
Haven't heard of this one before, but there is an excellent guide to replacing the camshafts in the garage shop manual at www.clarks-garage.com I'm sure you could use that procedure to replace just the bearings.
What makes you think its the bearings?
Rick,
I got my S2 back from Motor Preperation, they done a fantasic job on my wing. Spent all weekend polishing the rest of the car to shine.
Thanks for the contact[:)]
Hi Paul
Thanks for the advice. Basically, the noise is coming from a bearing housing located between the distributor and cam cover. I have already replaced both tensioners and idlers and held the water pump while the engine is running- and the whine is still their.
Laters n.
Thanks for the reply.
I have changed both tensioners and idlers + checked water pump + slackened of belts and the noise is still their_the whurring noise seems to be coming from the distributor housing.
laters n.
Rick is referring to the forums at www.rennlist.com
This is a massive US based site and has been around much longer than we have. Anything really technical is always worth searching on there as the US owners are very in to DIY engine rebuilds etc
Do asearch in the extensive 944 sections, we'll see you back here in around a few weeks [:D][:D][:D]
