Can’t open door on my boxster
- Thread starter Por911
you have to do this to pop the bonnet to get at the battery or you can find the manuAl bonnet release cable behind the left wheel arch and manually release the bonnet.
if you open the door you can also jump the batter from the special point in the fuse board.
good luck
once the door is open you can hook up a charger to the charge point in the drivers footwell behind the panel and get your battery up to strength again and it'll be fine after a while on the charger.
