Can any of you bright twin sparks tell me how to....
Change the O/S door mirror motor on my 993? Is it a door card off job? I removed the mirror glass & saw the motor wires disappearing into the door. I'd really appreciate knowing the answer before I start the job. Cheers!
What a coincidence! I have just completed this very job!
It is incredibly easy and can be done in the comfort of your living room. At the top of the mirror base where it meets the door there is a rubber grommet. Use a thin screwdriver to remove this and you will see a philips head screw. Turn this anti-clockwise (holding the mirror housing) and the whole mirror unit will come off. One you have done this, there is a plug that can be removed and you should now have separated the unit completely.
In the warmth of your living room or garage, you can remove the mirror glass (you obviously know how to do this) and you should be faced with three philips screws that hold the motors in. Simply unscrew these and the motors should drop out.
The new motors I purchased had a plug that did not fit my particular mirror for some reason, so I just clipped the wires and reconnected them.
As they say, refitting is the reverse of removal.
Let me know how you get on or if I've steered you wrong in any way.
EBay came to the rescue with a brand new one. The seller was Europorsche in Wembley. I managed to get it for £17 plus p&p, but Porsch-Apart were quoting £20 plus VAT and p&p and I was going to use them until I saw this auction. To be honest, it's not something that comes up on eBay very often, and as I'm the only one that drives the car it wasn't at the top of my DIY list as I rarely use the mirror adjustment.
Thanks sidned, you're a star! New motor now in place, easy job all thanks to that little allen nut under the rubber plug! Now my mirror doesn't wobble around any more AND has electric adjustment like it should.
