Can Cliamte Control Be Retro fitted?
- Thread starter the_big_1
Black80XSA
For 986 cars there was only difital climate control, or basic rotary dial ventilation - to upgrade you'd have to install all the air con pipework, condesnors etc , which is too cost prohibitive.
Black80XSA
ORIGINAL: the_big_1
Cheers, So stick to digital fitted, check for debris in side vents. Will do! Cheers,
Carl
Front, not side...
Would that be the case if they had been cleaned out regularly? Mine (2004) look pretty clean with no sign of rust - they certainly don't look to be on the way out.ORIGINAL: Black80XSA
...bear in mind that at 5-6 years old condensors/ rads will need replacing (about £500 a side)...
Black80XSA
Perhaps not, but the area does still get infiltrated by road salt and rainwater, so its never the best environment. If you could keep them squeaky clean then i suppose they'll last as long as any other radiator, which could be many years. Thedebris also get trapped between the air con rad and the coolant rad behind so you do need to get a thorough clean in there from time to time. If the car gets little use in autumn and winter times then this will obviously reduce leaf debris ingress.ORIGINAL: spyderman
Black80XSA
http://www.realtime.net/~rentner/Porsche/Radiator/Radiator.html
