GOOFY
Hi
Faced with faulty solenoid problem on my Boxster.
Background : Car was covered and not used during winter and spring. Started last month and the symptoms began soon after: very uneven lumpy idle, CEL light came on once then off, but engine performs well on high revs. Luckily engine light went off just before MOT and then soon after it went on again and rough idle began ! Seemed intermittent at first but now rough idle but no CEL.
Went to independent who put durametric on it and ELEVEN FAULTS FLASHED UP !! I suspected Variocam solenoid and then asked to switch variocam on and off on the left and right banks using the durametric and sure enough the right hand bank did not make any difference.
So can the solenoid be replaced without removing camcover (MY 1998 2.5) . Also is there a possibility that it could just be a wiring issue, or worse could it be actuator .
Any advice much appreciated.
