can you name all the parts ?
peanut
and now ...back at popular demand ( well only Oli actually) for your delight and delictation, a parts quiz .
Actually I still don't know what all the parts are myself lol.
OK best shot lol.
Airflow meter
Not on my turbo. Doesn't the S2 have an ignition amplifier?
Not on my turbo
Ditto
Vacuum resevoir
Connector for heater blower maybe?
Possibly headlamp levelling motor. Could do with a better view.
Throttle position switch
Fuel damper or pressure regulator
Bonnet switch possibly for bonnet light now probably used for the alarm
Lol do we get a score? Maybe be even a star or perhaps a must try harder see me [:D]
All of these are from an S2, as I recognise the orientation and position of the AFM:
AFM
N/S counter balance for pop-up headlight
Junction box next to Clutch Master Cylinder
Junction box on N/S in front of the fuse box
Driver's side, inside the bulk head, vacuum reservoir with the washer pipe
View from the N/S looking into the heater/blower unit under the plastic scuttle cover
O/S headlight mechanism showing the levelling motor
TPS
Fuel pressure stabliser/ pulse remover
Under bonnet switch for both the alarm and activating the under bonnet light when the headlights are on.
C
Ah so the counter balance was the subject of second photo. I was looking at the small module to the right.
Thanks Nick! Answers are embedded below.
ORIGINAL: peanut
Air flow meter. (Easy)
Back of the headlight mechanism on the LHS. RHS - dunno. It looks like a thingy that plugged into the hall sender on Mk1 golfs, but I don't know what it is on the S2. (And have never noticed it on my car.)
Wiring loom connector. Not sure which one.
Pretty sure my S2 doesn't have one of these. Are you sure it's standard? Those screws don't look very Porsche-esque.
Dunno, but have often wondered. Vacuum reservoir of some kind? Odd shape for it. What happens if you disconnect it?
Connector. For the heater fan, I think.
Headlight height adjustment motor (at a guess. Not sure whether my S2 has this.)
Connector on bottom of air flow meter.
Fuel pressure regulator.
Bonnet open switch for built-in alarm.
How many did I get right?
ORIGINAL: chrisg
Under bonnet switch for ... activating the under bonnet light when the headlights are on.
No - 'tis done with a mercury tilt switch in the back of the under-bonnet light. (Never understood why it wasn't wired into the push switch but it wasn't!)
ORIGINAL: robwright
OK best shot lol.
Airflow meter
Not on my turbo
Ditto
Vacuum resevoir
Must try harder !
actually I have no idea what half of them are myself. [:D] let it run a bit and we'll see who did the best
AFM
Ignition Amplifier
Loom plug for cruise control
Cover for engine bay wiring loom multiplug
Vacuum reservoir
Connector for wiper motor and also vacuum solenoid for air recirculation
Headlamp level motor
Throtle position sensor
Fuel damper
Bonnet open alarm sensor
Need to get some harder pics boys!
Alasdair
ORIGINAL: Northern924
You do know Alasdair is stripping a car at the moment don't you LOL
ahhhh.....cheating eh ? [:D]
I shouldn't think that there were many parts of a 944 that Alastair wouldn't know intimately to be honest.[;)]
ORIGINAL: zcacogp
ORIGINAL: robwright
Get in got the ignition amplifier and haven't even got a n S2. Got to be worth an etra mark????
Aspiring to greater things? [;)]
He needs to purge himself of the turbo experience before he can upgrade to an S2 [:D]
ORIGINAL: peanut
Very true! Just hope my post doesn't bump the price of the next batch of parts up
