Outrun944
Hey guys,
'85 LUX (not a 85.5) with a square dash ... I'm wondering how trustworthy the dials are.
1) Temperature
I'm mostly driving in evenings when its getting dark with lights on. I've noticed, after a while driving and say you get stuck idling in traffic - temperature always rises - but after being stuck for a long while in bad traffic or a 'spirited run' the needle is getting near towards the red. The main fan DOES come on and work fine, I had the fan checked over when I replaced a thermo fan switch. On my old 944 it used to come on at the 3/4 mark then temp would drop below the 1/2 mark eventually - now its nearly at the red zone when that happens. HERES THE KICKER - I had pulled over and switched off my lights - the needle nearly jumped down a whole quarter from past the 3/4 mark down to the 1/2 mark!
LOL - so what do I trust? Lights on or lights off? hehe! OR do I have fault electrics?
2) Oil Pressure
Strange fluctuations. It should be at 4 when driving, then drop to 2 when idling yea? That's pretty much the rule of thumb and standard. Sometimes on a run, the pressures at just about 3 when driving, and drops to about 1.5 idle. Seems intermittent.
Checked the oil levels and its topped up to just below the full mark as it should be.
Trust the dial? Or something else going on?
Cheers guys! Appreciate your advice and opinions ... still learning my way around this wonderful but sometimes strange car [
1) Temperature
2) Oil Pressure
