Car Judders at low revs
- Thread starter Guest
A little more information please.
1 Do you think the issue is engine related? does the engine rev smootly and return to idle as it should?
2 Does the clutch feel like it's taking up evenly or is it jerky. How old is the clutch
3 Do you think the issue is nothing to do with the engine/ clutch could it be wheel balance/ drive shaft related?
John
On the clutch: 3rd 4th and 5th gear change smoothly, It does not slip, when you are in traffic and go from are in 1st or go to 2nd at low revs. The previous owner (2 weeks ago) said he got the clutch adjusted
On cutting out: The engine does rev smoothly. However when driving to a halt sometimes the engine revs dip, red light flashes and it cuts out
There is a Alarm drain on the battery (i cant find it to turn it off with key), It has cut out on me twice at stationary position and on a few attempts started up but sounded like the battery was near flat
Dave
bones
Just a thought, your idle speed should be around 950rpm how does this compare to yours, are the exhaust gasses at exit from the tail pipe rhythmic or are they erratic ( splashy)? Erratic would suggest a weak mixture which could also cause stalling on run down. I am assuming your mixture setting in done manually.
John
