Car Parks again!
- Thread starter Nouveau
peanut
If the wing could be removed you might stand a chance of pressing it out flat with a hydraulic press but you would need to remove any trace of underseal from the underside.
I would be inclined to try using a G clamp in situ . Clean the underside and use a smooth block of steel on the underside and a cloth wrapped block on the paint side. It should improve it a bit without causing any damage.
Its almost inevitable now to get damage in car parks . I try to park in 2x spaces if I can so there is plenty of room for doors opening. Selfish but 944 doors are difficult to open in narrow spaces.
