Hi
Unfortunately, the 996TT won't start. The instrument cluster is showing a n engine sign and the words "Fault Indicator. I have used the garages OBD code reader and it has shown the following codes;
"DTC 9110 DME control unit
DTC Trigger
- ignition on
- possible cause of fault
- Short circuit between CAN - high and ground
- Open circuit of CAN - high drive
- Open circuit of CAN - low drive
- DME control unit faulty
Remember
The CAN drive bus is connected to the following control unit
- DME
- Tiptronic
- PASM and steering angle sensor
- Instrument cluster
Check the follow
- Instrument cluster connector A pin and 31 pin (CAN drive)
The other code is below which is exactly the same as above, except for the DTC 9111 PSM/ABS Control unit bit.
DTC 9111 PSM/ABS control unit
DTC Trigger
- ignition on
Remember
- DME
- Tiptronic
Check the follow
- Instrument cluster connector A pin and 31 pin (CAN drive)"
I have:
- checked the fuses
- the relays drivers side and the rear
- the battery (Bosch) is 6 months old.
Any ideas what this could be?
Any advice greatly appreciated.
Thanks![Thumbs up (y) (y)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
DTC Trigger
- ignition on
Remember
- DME
- Tiptronic
Check the follow
DTC Trigger
- ignition on
Remember
- DME
- Tiptronic
Check the follow
I have:
- checked the fuses
