dirtydirtyharry
I spent yesterday putting my old interior back in.
Today the car wont start at all. The engine wont tick over whatsoever, all that happens is that the air circulation system kicks in, thats all you can hear.
The only 'material things which I actually did were to try and fix the boot release switch (in drivers footwell). I shorted the 3 different connections on the back of the switch a few times, caused a few sparks but that was it.
I also found one of the sunroof motor leads near the battery had come loose and reattached it.
I dont think I have done anything else which could have caused any starting issues.
Im currently charging the battery but I only charged it recently and dont think it will be this.
The clock isnt actually working. Does the clock normally display regardless of the key being in the ignition.
Im wondering if shorting the connections on the back of the boot release switch could have blown a fuse??
Any help much appreciated as always, im supposed to be at work tommorow but may not be able to unless I can get the car started. [
