carrera 2 driveshafts
bruceb
Hi all
I was wondering if anyone has had to replace a driveshaft on a carrera 2 due to worn cv joints?
Ok thanks for the response Maurice,
reason I ask is that there's a slight vibration and harshness in the transmission at speeds over 80mph, and its not wheel balance.
I had the same thing on my SC and suspected it was worn CV joints, sure enough they were, and after replacing all four the car is as smooth as anything at any speed, it made an incredible difference to the way the car drove.
I had the rear wheels off the 993 last weekend and spent a bit of time checking the cv's and there's one outer that I'm not happy with.
So can the outer cv be changed on its own?
Have you tried cleaning the brake discs out? Sometimes brake dust can accumulate in the drilled holes. Another thing to check is the location of your locking wheel bolts. I think these need to be positioned opposite the valve or something. I'm sure someone else will correct me if I'm wrong.
What do the Rubber Boots look like - have they split. They wear very rapidly if grit gets in. If they are ok then you would be unlucky to have one fail.
