Looking at my car the ride height looks a little too high both at the front and the rear. On measuring from the ground to the underside of the wheel arch through the centre of the wheel the heights front and back read: Front, 26 1/2", Rear, 25 1/8". The wheels are 16" Fuchs. I was under the assumption that the ride should be slightly nose down?
What I would like to know is: Whats the comfortable/minimum height I can achieve without resorting to fitting a bump steer kit. This question has been covered quite some time ago but the bump steer kit was not mentioned regarding the adjusted heights which were mentioned in the thread.
