mikeacollins
Hi guys. Need a bit of advice. I purchased my 3.2 carrera Targa about 6 months ago. It is a 2 owner car with only 49,000 miles on the clock. It has a full service history, serviced annually and I have all of the receipts. For some reason over the past 500 miles the car has started smoking on start up. It has only just started doing it and it is on start up only. Even stranger it does not always do it.... Sometimes if you take out of the garage to clean, put away and start the next day, loads of smoke. If it has been on a run and then you put it away, and start the next day possibly nothing... It is definately blue oil smoke, the oil is not over topped and is mobil 1. The car is faultless except for this. Has anyone any ideas what may be wrong. I am aware that a top end rebuild can be required at between 80 to 100k miles but his is only 49k and did not smoke at all 500 miles ago.... I use shell optima petrol. [
