Hi,
Last December the car cut out and failed to restart. investigation isolated the problem to either an intermittent connection between the main relay board and the DME computer or a possible problem with the computer. No fault was found, but after "playing"with the relay board and disconnecting/ reconnecting the computer the car started and until today has perfomed perfectly.
It's done it again! This time in my garage not on the open road. I know that pin 85b at the DME relay goes to pin 3 on the computer, it chects out ok. Can anyone tell me to which pin on the computer pin 87 goes?
I changed the DME relay last December. I have power to the computer, the engine turns over easily and I can smell fuel.
Assuming the wiring checks out ok is it possible to get the computer checked?
Thanks in anticipation
Fred
Fred
