Carrera Badge
964rh
Hi
Does anone know where I can obtain a rear deck Carrera badge in Red for a 964?
Rob
Rob,
You'll be hard pushed to find anyone with the correct 964 badge in BLACK - never mind red. They are not produced in red - so your only solution might be to paint it.
Bear in mind that many of the retailers offering the "Carrera" badge will sell the 993 part (Part no. 993.559.237.00) often citing models years 1989-1998 whereas the correct 964 part (Part no. 911.559.037.00) seems difficult to get (in black only). The two insignias are very different - the 964 part being substantially larger than the 993. If you get the wrong one, the "4" doesn't match.
Dave
Pete,
The Porsche parts supply chain never ceases to amaze me - their ability to deliver quite obscure parts, often from stock in Reading, is incredible. It wouldn't surprise me if said insignia was available from the OPCs - and probably cheaper than many independants too perhaps!!! It just needs a phone call to an OPC for them to check the Reading stock.
Dave
ORIGINAL: OllieW
Rob,
I might be able to source the badge in red, but it would be in vinyl...
[:D]
My first thought Ollie!!!!
Perhaps I should've said I want this for the rear shelf. I'm having the top and upper half of the rear shelf covered in carpet to cut down on glare in the rear screen and removing the rear seat backs.
I know you can have this embroidered on the carpet but wanted something different. i.e. a red carrera badge.
I don't really want to paint a black one so I may have a look at putting a hood crest there instead.
Unless a vinyl supplier can wrap a black one in red??!?!?[:D]
Rob
The crest would look good there, and would possibly be easier to fix in place compared to the carrera wording badge.
Wrapping a script badge in vinyl would be a real challenge as it is too curvy.
What about spraying one in Guards Red after coating it with a primer?
Well would you believe it!!!
OPC Nottingham have one in stock, the correct one for the 964 at £12.00 including vat + post.
Just need to get some paint now.
Rob
Rob
I'm not using this for the rear deck, just the back seat.
Didn't really want to put the 4 on the back seat, just the carrera bit.
Going to enough of a pita to secure that!![:D]
Rob
