PAG ZERO1
Hi Guy,
Has any fitted the larger rear tyre size on the C2S, I know the 305/30R/30R19 is standard on the C4S which has a slightly wider body at the rear, but reading the manual some C2S are fitted with the 305 vs 295. The 10mm difference on width would seem to easily fit on the C2S body as there seems plenty of room, I no this would just be cosmetic but would be interested in your comments and if anyone has fitted the larger tyre to a C2S ?
Carrera S Coupe
(front) 235/35R19
(rear) 295/30R19
Carrera 4S Coupe
(front) 235/35R19
(rear) 305/30R19
Carrera S
1,425 kg (3,142 lb)[33]
8.5×19in, 235/35ZR19
11.5×19in, 305/30ZR19
Carrera 4S
1,555 kg (3,428 lb)
8×19in, 235/35ZR19
11×19in, 305/30ZR19
Carrera S Coupe
(front) 235/35R19
(rear) 295/30R19
Carrera 4S Coupe
(front) 235/35R19
(rear) 305/30R19
Carrera S
Carrera 4S
1,555 kg (3,428 lb)
8×19in, 235/35ZR19
11×19in, 305/30ZR19
