Here is a bit of the thread where Guy was answering questions for people on PH's Porsche forum:
http://www.pistonheads.com/gassing/topic.asp?t=124186&f=48&h=0&hw=oil+993rs
I said:
"opie
oilman,
I wonder what you think of the
oil I have in my 993 RS, castrol RS 10-60? Surely a large viscocity gap there?
Many thanks."
Guy said:
"Johnny,
I am afraid you are using very much the wrong
oil here. Porsche recomend a 5w-40/0w-40 for all modern engines and only go upto 10w-50 under extreme track use.
The RS 10w-60 is not a true synthetic and does not carry the Porsche approval.
I would change to something else that is Porsche approved as the poor car is going to be choking trying to pump this around.
Guy".
So I said:
"Right, I'll look into it!! The thing is, my car IS used under extreme track conditions.....full tilt for 2 days at Bedford last weekend is an example, then 2 days at Spa in May.
Perhaps Mobil 1 15-50 is in order? Or is that too thick? You never see anything other Mobil 1 for sale other than 0-40 and 15-50, or am I not looking hard enough? Or what 5-40 or 10-50
oil should I use?"
So he said:
"If you are doing hard track work then in my opinion the Castrol really aint upto the job even if it is the right grade, because it is a mineral based
oil it will shear down under hard use, so with a few hours on the track your 10w-60 is functioning as a 10w-50, then 10w-40 and so on until your left with dish water.
True pao and pao/ester synthetics have uniform base molecules so are very shear stable, so after a few hours on the track, the true synthetic 10w-50 will remain a 10w-50 and so on.
Mobil 1 is very good but Porsche do not recomend a 15w for the car, ideal
oil for you is the Silkolene Pro S 10w-50 ester/pao synthetic.
Ester based
oils are even higher quality then the straight pao
oils like Mobil 1 and even more stable yet again as they are actually polar.
Make sure your
oil is Porsche approved.
If you would like more info on suitable
oils for you car, just drop me a mail through my profile.
Guy."
I thought this made sense, so I went for it! (The Silkolene that is).
