artfailier
Hello All,
Some time ago I posted several pieces about a mysterious missfire on my 2003 C2 Targa. After much investigation and frustration over the last year ,it has finally been traced to the variable inlet valve lifters on cylinder 6.
I will shorten the story but the problem turned up three weeks after the waranty ran out and the OPC could not diagnose the problem. Much happened since -new battery ,coil pack ,MAF unit etc but it still did not fix it.
The car has been to the local OPC but I also took it to Parr who know what they are doing.
Finaly whilst talking privately to an OPC mechanic, he said -is it fairly low mileage? Yes - 23,000- Is it cylinder 6? Yes ,or a multiple missfire code- Aha, you need new valve lifters on the RH bank ,he said !!
It seems they have done quite a few 996s with this now at the OPCs.
I wrote to Porsche setting out the details of this tale of wow to see what the could offer to put it right bearing in mind it was first recorded by them three weeks after the waranty finnished - NOTHING was there answer. It is just a flook! Turns out that a new man at Parr knows all about this 'non exsitant problem'. They fixed it yesterday ,well I was not going to let an OPC get the money. So beware, I am told -don't use the car for short journies(which I don't).don't leave it for long periods. And if your missfire code shows cylinder 6 then get out your waranty card quickly!
All the best
All the best
