cayenne misfire/
- Thread starter h4rvy
NIL98
ORIGINAL: h4rvy
Hi Guys many thanks for your suggestions but after replacing all coil packs the problem is still there - could it be the gearbox ? my local porsche dealer says they have never had a cayenne with a dodgy gearbox - anyone help ??[]
Well they would say that........my gear box was replaced under warranty as it had a judder on the change between 3rd & 4th, on a bad day the judder was bad enough to feel it through the steering wheel & pedels. Although not quite a banging could be similar.
Dealer couldnt find what was wrong with the box so they ended up replacing it, although I did have to be firm with them on the issue!!
alex.powell
ORIGINAL: alex.powell
Alscoob - did you use your local dealer? think it may be the same as mine....
Most certainly did, Porsche Harston..and............. they are absolutely useless []. They are pretentious oiks and the girls on the service desks smile a lot but know nothing and despite telling them all the issues it goes in one ear & out the other.
My judder they said was coil packs so they replaced them, I also got them to change the plugs while they were in there, picked the car up. I asked is everything fine "yes sir, no problems now".. 50 yards down the road I turned round and took it back, was just the same! I had to take the mechanic out down the road to demonstrate the problem and he did admit that a few have these problems with the tiptronic box but most people live with it!!
I also had PSM & 4 wheel drive warnings come on at the same time.. new sensor they said.... now this is located below the low gear selector in the centre console, they obviously didn't check anything either because the selector was siezed when I got the car back.... they jammed the switch on the sensor when they put it back together!
They just gave up in the end and took the easy option they didn't know what was wrong with the gearbox, asked at the time to speak to the mechanic but no joy. Hope you have better luck with them than I did
