Cayenne Queries
Muzzer911
I have a MY05 KNS with air suspension. Everytime I drive the car I get the error message 'Air Suspension Faulty - Contact dealer'. However, the air suspension still appears to work! Is this a computer gremlin or will there be a problem (not noticeable) with the suspension.
I have 20" wheels and both rear tyres are 100% AOK. The front two tyres have got heavy wear on the outer sides. Is this normal? can it be rectified?
I have booked the car in at my local OPC. They have suggested the pump, which appears to be covered under the Porsche warranty.
Any thoughts on the tyre wear?
ORIGINAL: Muzzer911
Two Possibilities .. I have read a number of times the 20 inch tyres on the Cayenne do wear on the outside edge, do a forum search I am sure something will come up .. The other is simply Alignment as its outer wear I'd guess a bit too much of "toe in".. only way to check is a Laser realignment at a OPC which is about 200 GBP
