Cayenne recall
- Thread starter tiskev
The dealers at this time have not heard of anything - you sure it is not a USA only thing?
Cayenne Recall
Volkswagen and Porsche have said they are recalling more than 800,000 Touareg and Porsche Cayenne sports utility vehicles because of a fault with the pedal mechanism.
The carmakers said 391,000 Touaregs and 409,477 Cayennes built between 2011 and 2016 would be recalled because "a circlip could be loose on the bearing bracket for pedals”,
If you are the first owner of Cayenne with registered years 2011 until current 2016 , you should be contacted by Porsche UK to advise on recall venue.
Book in at appropriate Porsche Centre ( or contact nearest one to your residential address ) for recall action
Should you be a subsequent owner [ second, third owner et seq ]- it is "hoped " that you may be informed via the vendor as first owner. - ( pigs might ... springs to mind !) Therefore I suggest it is more prudent to take action yourself and directly involve your local Porsche Centre to join their program of rectification. The procedure , I understand, involves a pedal bracket only and is not time consuming. The recall covers all models I am lead to believe.
Hope this helps
pboldmonts
