Cayenne Turbo 2005
paul@riccall
Has anyone experienced having only hot air being blown out on one side of the car only ? The passenger side has very cold air coming out of the footwell and dash vents. Whereas the drivers side has warm air coming out of the dash but cold air in the footwell.
Really annoying as it is probably warmer outside the car than in.
Thanks for any help
Paul
Unfortunately there are something like a dozen servo's in your dashboard controlling the airflow. Sounds like one or two have got stuck/broken if you can here clicking when changing flows or generally then definately servo.
Need a specialist with a reader to tell you which one (s).
... and its a big job to replace the servos as several require the removal of the complete dash trim before you can get near them.
ok thanks for the info.
The car was in storage for 6 months so I'm thinking they may be stuck.
I've looked at a few articles on the web and 'heater flap motor actuator' gets a few mentions. I'll take the car to porsche to get a fault code list and will go from there.
