Cayman 981S 4 Year Service
- Thread starter Gazoak
AlistairF
Some items that appear in my manual as being on the schedule such as aux belt check were quoted as 'additional', as was the brake fluid change. I'd shop about and also check what is 'included' in the base cost.
I think originally they quoted £1,400 which was reduced to £1,200 with a 'free' belt check. A long way off the published costs at the time. I paid up but go elsewhere now.
AlistairF
Job Details Variant Quantity Total Replace Spark Plugs Every 60K Miles
Add. Maintenance - Spark Plugs
/ 90K Kms or every 4 Years (Composite Work) Without Wheels Removed
99917015190 SPARK PLUG
Op Codes: 03810050
Check Ancillary Unit Mounts And
Add. Maintenance - Every 80K Miles / 120K Kms or every 4 Years
Op Codes: 03850050
Add. Maintenance - Drive Belt Check 40K Miles / 60K Kms or every 4 Years
Op Codes: 03600050
Chassis Visual Inspection of all Rubber Mounts For Damage (Composite Work)
Check Drive Belt (Composite Work) Includes Rear Wall Flap Remove And Install
Brake Fluid Op Codes:
Major Service - Every 40K Miles / 60K Kms or every 4 Years
Maintenance M.Y 2014 > (Main
Work)
9A110722400 OIL-FILTER INSERT
90012310630 SEALING RING
99157362300 CABIN-AIR FILTER
99610731351 SEALING RING
10000000002 TOPUP/BAG
99157237100 AIR FILTER AIR SUCTION
00004400204 WINDOW CLEANER OUTER
00004330521 ENGINE OIL
Op Codes: 03160006
AndrewCS
COD981 said:In my experience dealers in Scotland don't participate in the fixed price service scheme either and those items marked additional even though they are required at that mileage/age are always charged separately so the service price is just that, the oil/filters and other checked
My experience was … Perth did participate @ £775, Aberdeen did not @ £1075 but when challenged matched Perth`s price - NB they are both owned by the same group.
Findmeupatree
thanks
I can’t find my list of Centres which offered fixed price servicing at that time, but they were in the majority. I’d phone around to get some alternative quotes; just make sure that they’re quoting like-for-like.
Jeff
Findmeupatree
on a plus note though ... if you want to continue your Porsche approved warranty you don’t need a 111 inspection anymore . You phone up and have your driving license and v5 ready and can buy it there and then . You can also purchase it well in advance of your existing policy running out . Just buying another 2 years myself , 6 months early , before they no doubt increase the price of it !!
