Cayman 987.1 ticking
- Thread starter Twinfan
Andywidmann
This is a 987.1 Cayman s. It's has 70k miles. It had bore scoring, which was fixed by a Porsche independent shop here less than 100 miles ago (engine out, new liners, etc). The only place it's really been driven since the engine out is back from their shop. Shortly after I got the car back it started making a loud ticking noise. I've sent the below video to the shop, and they said it sounds like a bottom end bearing failure (but would have to check), but it would require a full engine rebuild and since it's not related to new liners they put in it wouldn't be under warranty. They suggested I don't drive car and tow it back to them. Needless to say two engine out services a few weeks apart is going to be financially troublesome.
Though I would check with you guys on the interwebs to see if anyone had any thoughts? Video to link below. The noise it the same if car is cold or warm. Obviously ticking increases frequency with engine rpm.
https://youtube.com/short...ex4-O2o?feature=share3
Apart from tappet noise, the Gen2 DFI engines do exhibit ticking noise from the fuel injectors, but that isn’t appropriate for your Gen1 engine. It could be a very noisy tappet, but really you need to get underneath the car as well as taking the engine cover off to get close-up to the engine and so get a better handle on the source of the noise.
Since the engine has very recently been out for repair, I’d definitely be going back to the shop to let them investigate the problem. They’ve had to dismantle the engine to carry out the bore repairs [heads off, crankcases out, new pistons, rings and gudgeon pins, or new piston rings at least], and it’s possible that something has gone amiss during assembly, so don’t let them fob you off with any excuses. With the engine stripped, I would expect a reputable garage to check the condition of the big end bearings as a matter of course.
Jeff
Andywidmann
I'm going to try to get under the car and get the engine cover off to try and determine where the noise is from. Might also see if I can get a local shop to diagnose before I have it towed to the original shop, which is over an hour away. Theyre also saying they wouldn't be able to get to it until late July or August at the earliest, so I guess there isn't much of a hurry to get it back up there.
Andywidmann
Again, thanks for the thoughts. Will post when I have someting figured out.
In order to get to the crankcases the engine will have had to have been split into its component pieces [camboxes, cylinder heads, crankcases and main bearing carriers], which would leave the crankshaft, connecting rods and pistons/rings as a complete assembly, so I’m assuming that the repairer is maintaining that they haven’t touched the big end bearings? I assume that they’ve checked the condition of the main bearings, which would have been exposed, so I think it was very remiss of them not to have checked the big end bearings too while the engine was stripped. A no-brainer in my opinion.
Jeff
AndrewCS
I would ask the indie to come to you (with trailer) to listen to the car.
Take it from there...
Andywidmann
Andywidmann
Andywidmann
Andywidmann
https://youtu.be/mP3LuzJxmJ8
https://youtu.be/YJnRvXmfW9o
AndrewCS
AndrewT
