seanwarrencox
Hello, I have an 05 Cayman S but I suspect this will apply to anyone with a Boxster also.
My disc pad warning light is on. It comes on mostly as soon as I turn on the ignition, is does not come on when I first hit the brakes it is normally already on by then.
I have checked the pads and they are all fine, brake fluid level also. I suspect a wire break between a sensor and where they return to for monitoring. I would like to know where the other end of the sensor wire goes to so that I can put a meter on to check. Anyone know where this is located and if it is easy to get at ?
This is my first post so I apologise if this topic has already been covered. I tried a seach but could not find much.
Many thanks
Sean
Many thanks
Sean
