AndrewT
I can’t help with the dimensions (987 owner) but if the central brick pier will cause a problem for the door could you build with 2 brick piers and split the wall into thirds - although that may put them adjacent to each wheel causing access problems there. Carpet on the wall to protect the door is a good idea.
