Cayman options
- Thread starter m4ttc
If going 19" - are you also fitting PASM?
Do you fit the sport seats? (Are you comfortable?)
I woudn't bother with PCM, updates from Porsche for previous generations of Sat Nav are "patchy" at best.
Use a Tom Tom or PDA - cheaper and more updatable.
ORIGINAL: m4ttc
I am debating this and probably need to choose 2 from 3. I know not everyone agrees but resale must be considered.
Choose the 2 options which you personally want the most. If future residuals are a consideration the more basic you keep the spec the less you will lose in depreciation. Having the standard desirable options are usually metalic paint, speaker upgrade but not Bose, climate control, sports seats, and if you feel a like spoiling yourself a little full leather is usually quite desirable at resale time although you will lose half the original cost for sure. After that its all downhill residual wise [&o]
Dapster
If you are a slim build then sports seats will hold you in place much better than the rather flat normal seat - in the S these will be leather so there will be a greater propensity to slide about in them. I also recommend the sports steering wheel (much nicer to hold) and the bi-xenon headlamps.
