Cd changer
- Thread starter Hannu
Tool Pants
non Club member but v. knowledgable
You need a CDC-3 which is the same as a Becker 2660 Silverstone except it has the Becker name on it instead of Porsche. Unfortunately this Becker model has been discontinued as a Becker product, but Porsche $till $ells it. At least in the US. There are used and refurbished 2660 floating around in the US, perhaps in the UK as well..
The replacement for the 2660 is the Becker 7860. This unit is smaller and has a memory issue with the 22 (220 in the US) radio head.
Tool Pants
21 has the same specs as a 22 except the 22 has aux-in and the 21 does not. But you canot use the aux-in and a changer at the same time.
The same changers as Toolpants mentions above will work I believe,
Tool Pants
The option code for the actual changer is 692. So if you have 692 on the option sticker than someone made off with the changer.
Paul Fraser
ORIGINAL: michaelbarnes
I have CDC 22 which has a single CD. What multi changer would I need to buy? Any odea of cost?
There are cables under the bonnet just sitting there so I pressume the previous owner had a multi changer and took it with him/her?
You need the same as the CDR21 above. The CDC3/Becker2660 changers go for around £100+ on Ebay, IIRC, usually more. Think the 2660 new is around £275 from audio dealers.
