CDR22 or CDR32 in a 944?
edwardbreeze
Hi everyone,
not sure if if this is a common question but can't find anything online.
Im wanting to fit an OEM headunit and fancy a CDR22 or 32. Is it a straightforward fit into an S2? Size and wiringwise?
any help would be appreciated
If that's a Becker unit then yes should be fine. I have an Indianapolis in mine and I don't recall it being that much of an issue.
I don't think they have the nav options so that makes life easier. You'll need to wire in a DIN block as I doubt yours will have that but should be good then.
