Central Bearing Failure......
- Thread starter mooren
But the new engine seems OK - and it's 8K younger than the rest of the car []
Black80XSA
One is RMS, or the crankshaft seal
The other is intermediate shaft failure which lunches the internals.
Given that PCGB don't replace engines purely for RMS i would assume its had the shaft failure
RMS is usually a small oil leak. Unless the leak gets really bad, AND you ignore all the warning lights telling you that you have low oil pressure, I can't see how it would be related.
Dapster
So this isn't related to the RMS recall at all
There has been no RMS recall as this would imply an admission of a fault which off course, Porsche has not done....
There are two issues with the Boxster engines.
Add slipped cylinder linings to that.
