Central locking help
parnett
Evening. As a new member and owner of my first Porsche I need a little help with my un responsive central locking on my 2000 C4.
I haven't driven it for a few weeks so expected the alarm to have switched itself off. Usually this just needs a turn of the key and a blip to turn off the alarm as it activates.
This time however the alarm went off and only switched off after repeated blipping of the key.
Ok but now the car is locked on the passenger door, luggage compartment and filler cap. The central locking doesn't work but the car can be opened and locked with the key and driven. The alarm / immobiliser light flashes on the dash.
Is there a simple reset I can do or is it a garage job?
Apart from that I've loved every minute of the car so far.
Thanks in advance,
Paul
This sounds a bit odd. You say that you hadn't driven the car for a few weeks; how does the battery seem? Do you keep it on a trickle charger? It's probably a long shot but could it be that the battery is a bit depleted and the electrical system doesn't like the lack of amps?
I only mention this as I know that the 996's do start to behave strangely when the amp/hourage falls below certain levels - ie. the windows partially drop, the rear spoiler deploys, etc and the car generally goes a bit hatstand. I'm just wondering whether your battery has lost some of its power and is upsetting the electrics - something that you could easily find out by just attaching a battery charger and seeing what sort of charge that it's trying to put in to the battery. If the charge is down then I would say that the fault will resolve itself following a good (slow) charge.
Please don't fall in to the same trap as I did a few years back - thinking that simply driving the car around would give the battery the charge that it needed. It didn't, and I eventually ended up having to buy a new battery and an alternator! [:mad:]
All the best. Be nice to hear how you get on.
Adrian.
My C4 does that from time to time though not because I have to use the key in the door because of a lay up, the alarm will simply not disarm with the key every now and again. When I open the car with the key to disarm and switch ignition on, all but the drivers door stay locked. I can resolve it by locking and unlocking the door with the key again. It's a problem that is intermittent but probably getting more frequent - a key battery change has made no difference.
Thanks both of you for the advice. Not been home enough to try either but will do so on Monday and let you know if it's fixed.
Glad I joined up to PCGB now!
