Central locking
tref
ok... So starting with the obvious first, I checked the fuse. Blown. The replacement blew as soon as it was inserted... So... I have a short... any-one any idea of particularly likely culprits before I have to start wading through the wiring diagram and disconnecting stuff? TIA Tref.
Can anyone point me at an existing thread, or explain how the central locking should work, including the operation of the little switch on the centre consol (and it's associated light), so I can start to analyse how mine doesn't?
TIA,
Tref.
If it's a short, I'd be suspecting the connection wires where they pass through the door shuts. Movement = chafing = broken insulation = short. I'm not going to give a fat lot away on an open forum about the way the locking system works, but get the wiring diagrams from the usual source and it's all pretty easy. Oli.
That would be my "first guess" too... what I'm looking for is a connector that I can pull apart and isolate each door in turn/put a multimeter on and see which stops teh fuse from blowing/contains the short... I am guessing that is in the footwell or under the dash somewhere, or is it hard-wired through to the fusebox? Thanks for that, Tref.
Tref, Sorry, I don't know where such a connector is, or even if there is one. I'm sure someone on here will tho'. Oli.
clipped under the steering column is the central locking module. you can fault find from the plug on that in the workshop manual (It has a troubleshooting guide), which can be downloaded, from where i cant remember. Quite often central locking faults are down to the little plastic arms on the locking assembly, they break really easily. Best of luck
