Ripmax
Is there any reason why, after the battery has been disconnected for some time (weeks), the keyfob won't work the central locking? The key fob battery is new and I can see the LED flashing when I press it. The key works in the door lock and starts the car but not remotely. It was fine before the battery was disconnected. I had this last time I disconnected the battery but it cured itself during a two hour drive. I have a feeling it will cure itself again but I'd rather not drive it around for hours and it would be good to know the cause and to find out if there's a more technical solution.
