JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You should upgrade or use an
alternative browser .
bit of guidance required folks.
the passenger door on my 986 won’t lock.
had a new under seat ECU fitted and new key by wilmslow PC last year
divers door locks on the key and when the remote is pressed both door lock motors activate and drivers door unlocks
dashboard button doesnt activate anything, but it shows up as working on the laptop diagnostic
ive changed over the door lock unit today but it’s made no difference
wondering what else to mess with next....
Is it adjusted correctly? - I’ve known this to happen when the lock thinks the door isn’t properly closed.
kr Lee
Hi
It usually does this when the locking mechanism (in door lock) is'nt working properly.
Did you fit a secondhand part (its a common failure point so could also be dodgy), or a US/European part (the US/EU parts are for the opposite door and are not compatible).
If you have laptop diagnostics which you suggest you have - this should give you a pointer as to what the problem is.
dodgy locking units usually give a code based around the relevant side not reaching its limit and locking properly.
Thanks for the responses
I’ve Fitted a brand new door lock on advice of the technician who did a diagnostic check.
code references are
47 centralocking synchronisation
12 wrong door lock module
61 central locking Limit position unlock position not reached
Did you source it form the US by any chance - have a look at the error code as per below.
data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAlEAAADPCAYAAADVj4TEAAAKpWlDQ1BJQ0MgUHJvZmlsZQAASImVlwdUE9kax+/MpBdaIBQpoTdBOgGk11AE6WAjJJCEEkMgoIidRQXXgooI2NAVEAXXAshaEFEsLAL2ukEWAWVdLGBBZQd5hLfvnffeef+c78zv/OfOd7+5ufecbwCgXGOLRGmwAgDpwixxuL8XIzYunoF/DiD0RwT2QIXNyRR5hoUFA1TT179r7B46FtVti8lc/37/v0qRm5TJAQAKQzmRm8lJR/k0Gic4InEWAAgX9fVzskSTvBFlZTFaIMoVk8yb4hOTnDjFbd/HRIZ7o/wAAAKFzRbzACD/jvqMbA4PzUPBoGwl5AqEKNuh7Mbhs9F5KOg9MDs9fekkH0DZJPGf8vD+ljNRlpPN5sl46l2+i+AjyBSlsZf/n8vxv5WeJpmeQw8NCl8cED45H7pm1alLg2QsTJwXOs0C7lRNk8yXBERNMyfTO36auWyfoGmWpEZ5TjNbPPOsIIsVOc3ipeGy/MK0ecGy/EksGSdl+kZMc7LAjzXNufzImGnOFkTPm+bM1IigmTHeMl8sCZfVnCz2k71jeuZMbRz2zFxZ/MiAmRpiZfVwk3x8Zb4wSjZelOUlyylKC5upP81f5mdmR8iezUI32DSnsAPDZvKEydYHCEAIYANOVtKyyX0FvJeKlosFPH4WwxM9JUkMlpBjOZthY2XNBGDyzE39pe/o388SRL8x42W0AOBUiJq8GY+tD8DZFwDQxmY8/bfodtgGwPkujkScPeVNbnWABSQgD5SBOtAG+sAEWAAb4ABcgAfwBYEgFESCOLAYcAAfpAMxyAF5YC0oAEVgG9gFysB+cAhUg+PgJGgE58AlcBXcBF3gLngMpKAfvAIjYAyMQxCEh6gQDVKHdCBDyByygZiQG+QLBUPhUByUAPEgISSB8qD1UBFUDJVBB6Ea6GfoLHQJug51Qw+hXmgIegt9hhGYAivDWrARPAdmwp5wEBwJL4J5cAacC+fDW+BSuBI+BjfAl+Cb8F1YCr+CRxGAkBE6ootYIEzEGwlF4pFkRIysQgqREqQSqUOakXbkNiJFhpFPGByGhmFgLDAumABMFIaDycCswmzGlGGqMQ2YNsxtTC9mBPMNS8VqYs2xzlgWNhbLw+ZgC7Al2CPYM9gr2LvYfuwYDoej44xxjrgAXBwuBbcCtxm3F1ePa8F14/pwo3g8Xh1vjnfFh+LZ+Cx8AX4P/hj+Ir4H34//SCATdAg2BD9CPEFIWEcoIRwlXCD0EAYI40QFoiHRmRhK5BKXE7cSDxObibeI/cRxkiLJmORKiiSlkNaSSkl1pCukJ6R3ZDJZj+xEnk8WkNeQS8knyNfIveRPFCWKGcWbspAioWyhVFFaKA8p76hUqhHVgxpPzaJuodZQL1OfUT/K0eQs5VhyXLnVcuVyDXI9cq/lifKG8p7yi+Vz5UvkT8nfkh9WICoYKXgrsBVWKZQrnFW4rzCqSFO0VgxVTFfcrHhU8brioBJeyUjJV4mrlK90SOmyUh8NoenTvGkc2nraYdoVWr8yTtlYmaWcolykfFy5U3lERUnFTiVaZZlKucp5FSkdoRvRWfQ0+lb6Sfo9+mdVLVVP1STVTap1qj2qH9RmqXmoJakVqtWr3VX7rM5Q91VPVd+u3qj+VAOjYaYxXyNHY5/GFY3hWcqzXGZxZhXOOjnrkSasaaYZrrlC85Bmh+aolraWv5ZIa4/WZa1hbbq2h3aK9k7tC9pDOjQdNx2Bzk6dizovGSoMT0Yao5TRxhjR1dQN0JXoHtTt1B3XM9aL0lunV6/3VJ+kz9RP1t+p36o/YqBjEGKQZ1Br8MiQaMg05BvuNmw3/GBkbBRjtMGo0WjQWM2YZZxrXGv8xIRq4m6SYVJpcscUZ8o0TTXda9plBpvZm/HNys1umcPmDuYC873m3bOxs51mC2dXzr5vQbHwtMi2qLXotaRbBluus2y0fD3HYE78nO1z2ud8s7K3SrM6bPXYWsk60HqddbP1WxszG45Nuc0dW6qtn+1q2ybbN3bmdkl2++we2NPsQ+w32Lfaf3VwdBA71DkMORo4JjhWON5nKjPDmJuZ15ywTl5Oq53OOX1ydnDOcj7p/KeLhUuqy1GXwbnGc5PmHp7b56rnynY96Cp1Y7gluB1wk7rrurPdK92fe+h7cD2OeAx4mnqmeB7zfO1l5SX2OuP1wdvZe6V3iw/i4+9T6NPpq+Qb5Vvm+8xPz4/nV+s34m/vv8K/JQAbEBSwPeA+S4vFYdWwRgIdA1cGtgVRgiKCyoKeB5sFi4ObQ+CQwJAdIU/mGc4TzmsMBaGs0B2hT8OMwzLCfpmPmx82v3z+i3Dr8Lzw9ghaxJKIoxFjkV6RWyMfR5lESaJao+WjF0bXRH+I8YkpjpHGzoldGXszTiNOENcUj4+Pjj8SP7rAd8GuBf0L7RcWLLy3yHjRskXXF2ssTlt8fon8EvaSUwnYhJiEowlf2KHsSvZoIiuxInGE483ZzXnF9eDu5A4luSYVJw0kuyYXJw/yXHk7eEN8d34Jf1jgLSgTvEkJSNmf8iE1NLUqdSItJq0+nZCekH5WqCRMFbYt1V66bGm3yFxUIJJmOGfsyhgRB4mPZEKZizKbspTR5qZDYiL5QdKb7ZZdnv0xJzrn1DLFZcJlHcvNlm9aPpDrl/vTCswKzorWPN28tXm9Kz1XHlwFrUpc1bpaf3X+6v41/muq15LWpq79dZ3VuuJ179fHrG/O18pfk9/3g/8PtQVyBeKC+xtcNuzfiNko2Ni5yXbTnk3fCrmFN4qsikqKvmzmbL7xo/WPpT9ObEne0rnVYeu+bbhtwm33trtvry5WLM4t7tsRsqNhJ2Nn4c73u5bsul5iV7J/N2m3ZLe0NLi0aY/Bnm17vpTxy+6We5XXV2hWbKr4sJe7t2efx766/Vr7i/Z/PiA48OCg/8GGSqPKkkO4Q9mHXhyOPtz+E/OnmiMaR4qOfK0SVkmrw6vbahxrao5qHt1aC9dKaoeOLTzWddzneFOdRd3Benp90QlwQnLi5c8JP987GXSy9RTzVN1pw9MVZ2hnChughuUNI438RmlTXFP32cCzrc0uzWd+sfyl6pzuufLzKue3XiBdyL8wcTH34miLqGX4Eu9SX+uS1seXYy/faZvf1nkl6Mq1q35XL7d7tl+85nrt3HXn62dvMG803nS42dBh33HmV/tfz3Q6dDbccrzV1OXU1dw9t/tCj3vPpds+t6/eYd25eXfe3e57Ufce3F94X/qA+2DwYdrDN4+yH40/XvME+6TwqcLTkmeazyp/M/2tXuogPd/r09vxPOL54z5O36vfM3//0p//gvqiZEBnoGbQZvDckN9Q18sFL/tfiV6NDxf8ofhHxWuT16f/9PizYyR2pP+N+M3E283v1N9Vvbd73zoaNvpsLH1s/EPhR/WP1Z+Yn9o/x3weGM/5gv9S+tX0a/O3oG9PJtInJkRsMft7K4CgAScnA/C2CgBqHNo7dAFAkpvqib8LmurjvxP4TzzVN3+XAwBVHgBErQEgGO1R9qFhiDIFvU62RJEeALa1lcU/lJlsazOVi4J2ltiPExPvtADANwPwVTwxMb53YuLrYbTYhwC0ZEz14pPCoV8oJ7CT1KG9Cvyr/gIu9gFTuZeg3AAAAdVpVFh0WE1MOmNvbS5hZG9iZS54bXAAAAAAADx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6bWV0YS8iIHg6eG1wdGs9IlhNUCBDb3JlIDUuNC4wIj4KICAgPHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj4KICAgICAgPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIKICAgICAgICAgICAgeG1sbnM6dGlmZj0iaHR0cDovL25zLmFkb2JlLmNvbS90aWZmLzEuMC8iPgogICAgICAgICA8dGlmZjpDb21wcmVzc2lvbj4xPC90aWZmOkNvbXByZXNzaW9uPgogICAgICAgICA8dGlmZjpQaG90b21ldHJpY0ludGVycHJldGF0aW9uPjI8L3RpZmY6UGhvdG9tZXRyaWNJbnRlcnByZXRhdGlvbj4KICAgICAgICAgPHRpZmY6T3JpZW50YXRpb24+MTwvdGlmZjpPcmllbnRhdGlvbj4KICAgICAgPC9yZGY6RGVzY3JpcHRpb24+CiAgIDwvcmRmOlJERj4KPC94OnhtcG1ldGE+Cjl0tmoAAEAASURBVHgB7Z1LqB1V9ocrYiIoJE5UMD7SSDtQITahJepAM1CbCGoPdGAUlagDFXzR4mOgGfhA8dEQHfhAxUeD0viASGsG6h/UYDAqRAcG8S2o0Goahejg/ve39Veuu2/VOeee+6hz7v0tOKeq9mPttb+9T9WqvfepWjKRpLKYgAmYgAmYgAmYgAlMi8Be00rtxCZgAiZgAiZgAiZgApmAnSh3BBMwARMwARMwARMYgoCdqCGgOYsJmIAJmIAJmIAJ2IlyHzABEzABEzABEzCBIQjYiRoCmrOYgAmYgAmYgAmYgJ0o9wETMAETMAETMAETGIKAnaghoDmLCZiACZiACZiACdiJch8wARMwARMwARMwgSEI2IkaApqzmIAJmIAJmIAJmICdKPcBEzABEzABEzABExiCgJ2oIaA5iwmYgAmYgAmYgAnYiXIfMAETMAETMAETMIEhCNiJGgKas5iACZiACZiACZiAnSj3ARMwARMwARMwARMYgoCdqCGgOYsJmIAJmIAJmIAJ2IlyHzABEzABEzABEzCBIQjYiRoCmrOYgAmYgAmYgAmYgJ0o9wETMAETMAETMAETGIKAnaghoDmLCZiACZiACZiACdiJch8wARMwARMwARMwgSEI2IkaApqzmIAJmIAJmIAJmICdKPcBEzABEzABEzABExiCgJ2oIaA5iwmYgAmYgAmYgAl06kR98MEHboEhCTz77LPVF198MWRuZzMBEzABEzABE5gpgc6cqNdee6065phjqiVLljR+hq3Ye++9V91yyy3VY489NqyKvvmOPfbYbDPl9JNvv/0220PaTz/9tGdy0j7//PPVOeeck/WzjUL8ySefXMcddthh+ZhwiwmYgAmYgAmYwPwS2Ht+i/ujtO++++6Pg1ncwwnZtGlT1njhhRfOouY/VL3//vt/HPTZe/3112t7cIBWrVrVmuOKK66oGGFqkzVr1lRffvnlpGj0E+5RqUlYfGACJmACJmACc06gMyfq7LPPriYmJnIFGY1CjjrqqGq2pvhOOumkrHMuvl599dUKJxB7Z1N6OUKM3MmBgh31w+lCFD6btliXCZiACZiACZhAbwKdOVHRLBwCRlQOOOCAGFwxNXfbbbdVmq666qqrqrPOOiunuf/++yeN2hD366+/Vvfdd1+ORx8jPxwz/VYK4YxaEUc+nDfSxyk69nFeEOIoY//998/5sI2RrqOPPjrbhB7i3nzzzWwv6YmP+sh/ySWXVJdffnnWWX49/PDD2Tlbt25dGZXt3Lx5c7Vr166sg3LlRE1J7AATMAETMAETMIG5J5BGgzqX5EQxJDXBNkpyqupw4vkkJ2XimWeeyfvEp1GZvE/cIYccUu8rfRo1iirrfZVJuqgjOSo5jXSxlR2kQ5T35ptvzscqq9wSX4ZJR87Y8qU8vdLu3Lmz1t0rXUsRDjYBEzABEzABE5ghgb3SBXskhREcTZkxGnTZZZdlO++99956ym/fffetkqNSMb326KOPVu+88051wQUX5HSrV6+uvvnmmzyC1FRBRo2Q5BBVySnLW463bt2aR580Rfaf//ynevDBB4nKI18aFcsBxRdlo0vCaBT2SbA9xit8ults2LBhQ862YsWKSWVMV5fTm4AJmIAJmIAJDEdgZJ2oDz/8MNeILc7IAw88kI9ZeM1UFvLZZ5/lf/idf/75ecH2gQceWC/cxkniuE1WrlyZo8o0P/zwQ10WCShLDhfHTBO2CdN3aVRoUvTGjRvr46ZpxTpyGjtM42lx+0MPPVTzmIYKJzUBEzABEzABE5ghgZF1osp6MWLEByeFDyM6Z555Zk7GqBFrpaazKP2rr77KeRnNQlaFf82Va7NygiG/du/ePWTO5mw4ajiSjEAxAlc6bc25HGoCJmACJmACJjDbBEbWiVq7dm2ua1qTlKfXmNLDYbj77ruzs/TWW29Vt956a/X5559XpPnxxx+rl19+ueajkaw6oNjRqJCe3aQtI1OMfLUJZU1Hli9fPp3k9SL6MhNTeIceemj1+OOP5yim85juxKGChcUETMAETMAETGB+CYzEv/OanhmFw3Tttdfmv+/j1OzZs6fatm1b9fHHH+d9pveefPLJ7PBo/RJOhkaj0Mkxa5o0/deEFmcLR0ROl0a7cJbQywMvNTLFIw2OP/74JjWtYdggQRf/KmwbPbrnnnuqF198UcmzXeRh1I36qp4k4FhTnByntXFsLCZgAiZgAiZgAvNEYCRGopYuXTqlujgfLBbHgWEdEg4UDg6OBiNQ7GskhsxM7eGcMN0lpweng0cCNIlGnn755Zf8GAJ0kV8Ltp944ok8ZYaDhbOCTsptEqbWegmL3JFob1N66liuuaJ8RuF6ierbK43jTMAETMAETMAEZpfAEv7dN7sqZ18bjgTTe3FUh1IYdWIEiVGjOELEQytxSJC2UR9GeNCLM9bLSSENTkqvKT7KoUzZh11x9IupODlHbfZIB2uoyKu6xfTY0iRl/ZvSOMwETMAETMAETGB2CYyFEzW7Vf5NG04Rjk0/J2ouyrZOEzABEzABEzCB8ScwEmuiusDI2iRGsTwV1gV9l2kCJmACJmAC409g0Y5EjX/TuQYmYAImYAImYAJdEhiJheVdAnDZJmACJmACJmACJjAMATtRw1BzHhMwARMwARMwgUVPwE7Uou8CBmACJmACJmACJjAMATtRw1BzHhMwARMwARMwgUVPwE7Uou8CBmACJmACJmACJjAMgU6dKL2iRYaXxzyk0jKVQBfvyqMtepVLPA8ctZiACZiACZjAYiHQmRPFBffyyy+vOfM6F54iLuGCHY8VPp9b7Gt7SvhM7bjllluqa665Zig1J5xwQs+nrA+ltE8mXn1z7733tqYinncdLkThafj0xSVLltSOJP2T435Psl+IPFwnEzABEzCB3wh05kTxipT33nuvbgde08LDLzX69PLLL1erVq2q47vYKUfGZtuG+ELh6eo+9thjp5vF6YckoNf5kF1O9XTaDifswAMPHLJ0ZzMBEzABExhVAp05UQBZtmxZzUUXJ71jDieKlwkTjmPFqI3ecYdzw8gAI0VxConRAdKQlpGeKDyhnDzoY9SrTdBNmqapK3SQt3SuKJM8MZz82C3728pTuOyOOoiTPcQjcjLlgBIeGeREv38Rhx2xPuzziaIyynDZX4bHY9I0lS+dZX1iueOyrzrwomlG4/Ty6tJ+WMBcbUP8Dz/8kN/jyIuuo5D2sccem9RnYrz3TcAETMAERp9Ap07UUUcdlS/oXHTYv/LKK/NFRRceRqK4YB900EHVnj17qv333z/Hn3766fl1LUuXLq0OO+yw+kLENNdVV11VHXHEEflihiOFLl7o+9133+X35F1yySXVxx9/3NgylIVuLppPPvlk/dJgdDCSsH379ooXBJOGiyXCdA5lkodwHC2Ei+1xxx2Xj7/++uscVn5RZwQd2Eodow7CdHzWWWdlFhrRIA/24mjus88+peps37p166qLL764euONNyrYwI88Tz31VP2CZOw95phjsp3/+Mc/si3Ul4v8kUceme0izaZNm3IZ1BtnlDRI0zQe6U888cSsk61Y5Qxj+MUIKbJhw4a83bJlS97GL+pIP4X5X/7yl/qF2JdeemlO9uOPP+bpP5xwpb3ooosye3haTMAETMAExpDARIdy8803T5x99tkTmzdvzttnnnkmb1999dWJhDJbRnx6SXBtJceXXXZZfXz11VfnPASQh7yIdEddhJP37rvvZneKHHLIIRPYIKFcjrFv7dq1Cq7tle5vvvkmx+mYA9JHu+vMv+9E+yhXOiiPenDMVvagW/uEYxPbnTt3lqrzMWmTk1bHwY0ykWgnZSucMsWA9HwkOo55iSOvdLPFHtlPPLyjHsLGTagPXKg7W/ULwtXGsOaYvkUY+/RNtRPHcHjzzTdzu3BMHPrYb2vHcWNle03ABExgMRHodCSKESKmmxglSheYPBrFSAl36ukClK4tv0lcgE6IRnDYZ70JeUrRi4W1ZWQFQXdc4xLzsc4l6lac7NMxdqvM5CzV610YHUJUBnXqJ6SNa2bSBThn0eiHdKBb+yS44oorcjrVLx8UX73ilJQ6y25GubBF01eRhfb76YQVwuiKpk/FSmWO2zY5OrXJ9EumnMvpXtqL9mEqWaOR1Ju+S37aNTm2FbyVljj183FnVAPyjgmYgAksIgKdOlGnnHJKvqjcd999+SKDc8JFmrUiXMwl5YV75cqVisrbGK/F6OhC2OIAMDWFk0Da6IzkROFrv/32C0d/7JZTgCqzaSqNaTNENvyhZfIeF1alVYym63Tctr3gggtyvZ5++um2JDMOb1q8/uuvv07RKxYxgilO6nfnnXdWaZQlRo3dPtPDWkiOk7R69epJ/1QsHSC1u/IsX758Sp3Jw7/79I/Gsh9MyeAAEzABEzCBkSPQqROlCwdOkZwHRkU+++yzSY6ORjegx8jP1q1ba5CMCGgkhcBy0S8jPdz5sy5IC3/rzMUOuln3JFG5XBR37Nih4DxSQ5k4D4xKaJRLIzhNzkedOezgmJE2XoTZZ+RCdZJO6hEXxONoPvzww9Vtt90WNP6xS10GEcpSGaSHp5yAyFksVDfVmXCcDIkcKtZgMdKyfv36zF/x47ilneCkurGuLkrplNNWiNqgyYliBCoNeVeff/55HqE699xzcx5/mYAJmIAJjA+Bvbs2lQuQLsjYwvHbb789yayvvvqqPj7vvPOqU089NTsZOGFpjUmV1qrU8drRwmeNTLF4Gjn88MMrFlCXU4TE3X777RULuLkI8tGUGiNmpCcOh4+FxXxwNrAXe4jDsUlrhFA1qU45oOFLU2mM2OA0oQ+9cpbQxcJyFo8zWsfojgRnkdE6RtmYPirrU46cKV+5pSycAjmDLG6nvuhlUbicJ5w7OQs4EyyYhgULywnXdB91oD4sqsd26sNWecvyx+FYI0pyoqiLplNlP/XHAYXniy++mINjnelLMMSxQg/7tB9bPkz1xfTS660JmIAJmMAIExiFBWDlotryuMlGFk7zicKiXQmLpNNdfl74nO76FZwXB6fmqI/LHcpGL7pKOwhn4XAZzoJjymAribYoLG7RgX0SFhmni+gkHcRRZhke642etrJKe7R4XXpVNjooIzltCspbhVNndKkc7Ca9WHBc1kd2R1snKR+jAxbHw+b777+vraa9krNYM3v33XczE/pWctTrcDLAjjDi2OeTnK58zBZdFhMwARMwgfEjsASTR9jHm7FpjA5dd9111Y033ljxSASmqJIzUH300UdT1iPNuDArMAETMAETMAETWDQEFrwTRUsyzaJXljDVVE59LZrWdkVNwARMwARMwARmjcCicKJmjZYVmYAJmIAJmIAJmMDvBDr9d55bwQRMwARMwARMwATGlYCdqHFtOdttAiZgAiZgAibQKQE7UZ3id+EmYAImYAImYALjSqDT50TxkEc9iykCTH+fj4cD73/xxRfVtm3b5vV5Oyxa59lKPOdpGBEDFrzrgaPSo2cI8aDHjRs31g/BVLy3JmACJmACJmAC3RHodGE5jgcPeSwlPUdnKKeEV3LwL7z0bKL88EcctCbnpCxvJse8uoOHJ8YHhg6ij/RnnnlmdvpIX9b5lltuqTZt2lSroox33nmn9b1/dULvmIAJmIAJmIAJzAuBTkeiVEPeA6cnixOmV4softBtfP0Iozg4Ic8991x+mvigOoZJd/DBB08727Jlyyreu7dixYrqxx9/nJSfp6VjO44TrwP5+uuv81Otec8aDqLFBEzABEzABEygewIjsSaK15ow8qIPr3Nhao5XiDDSw+ecc87Joz1MnzGCxRbhNRvEMS2m6TDiNIrz97//vWKEqklIpzLQSZkSnDDFlc+V4lg2kV7vAGR0ibKI45UeOENtQh7imxxGnEGmNHmdC697SU8Gz2pU5zadDjcBEzABEzABE5g/AiPhRPFOOJwYPpLzzz8/r5dKr9zIU3I4NU8//XTFe8yYAtT7zFgDRZze8UZ+1igxwoOk123k43wQvnj3HC/J5b18lPHee+9Va9asqQjHecEx4wnnxPF+ONmGo8cx70rTO/70nj5eBsx0ItN0vLuO9+n1m+aT3mBanrJjxAlHCt2wQM4444yYzPsmYAImYAImYAIdEhgJJ+r999/PjlFcH/XEE0/kdULXX399vaBazko/Xjgmelkvr33BKSqFcIR0xD/00EPZUfrpp5+qO+64I8cxCkQc66qwjdEuTbOxLyeK6Tbkn//8Z37B7PPPP5/zMU335JNP5rhhv3DEKBsbmuoxrF7nMwETMAETMAETmBmBTtdEaRqM0ZtTTjmldpaoEiM5ODg4WHMhjDghGgli1Ef/CtQoV04QvjTaxSgUoulDwhkNQxgZYzpPwnEvaXMMCY8OFI6ZxQRMwARMwARMYHQIdOpEyYFgXRDrjyRMga1bty4vrOZlwTg1TK/Npuy3335ZHSNKOFJs+TefHKnplMUoEY8hQNauXTtpDRbHvUSOZJlGDtTNN9+c14qV8T42ARMwARMwARPolkCnTlRb1fXsKBwaFmhrtCimZ+QHZ0sjQMTFheFKq9EjHWur0SSVxWJxps127tyZHSn0svCbRd5Kgx04S6RjQfvu3bulLtvJv+lw+HCqGEljzRVO4KGHHlqnizssFJf9Kou0hFEGgnOpNJQND8vCJRD7wcKt5cKoGb9f/x4XRlu6FiYwNIGJDiUtwJ5Ihk+8++67k6z4/vvvJ5IjkuOIT4vE834alZn45ptv6mOFkyY9Z2kiLcbO6diiMzk1+Tg5Y5P0c1CWgQ70I5SRnKxJ5aMfQXcsl3zYijz66KN1HsJXr16ddeXI4ovySRM/slP1iHHaL9T4cJ4I0DfUBnG7efPm3P7qHzInOeN1v1BYvy260J3+zNAv6aR4+jr5EPpuacukxIvwgPMMbAcVzhvlOSn9QaXOTl/QOYDwkje/e3TwG58N4fxSlqHzWy/9nI+mU+9euhRHudgTBduuvPLKHESdOY/BBwbsRw76XcymXZRRthfHOp9GW+M+/YLfy2wL/QP2cylw5NMktAc2zJd88skndVGDcK8TL5Cd3868HVWGDvz555+3lk5nSCM5U+LpPDgaTT+AeLJBN+n6lUGapg5JeHq8wJRyKFd50B3zcswJgvh+Qpr4UV1ld4xjX/H99Dp+7gjQNjjYUbio0D6lNPXPMk085qTfpCemadqnz8uJIn95kWvKs5jC2tqnjQEs43mEdOIr1nICaDPFkY7fKMdNOogfRpp06RzUSx8X0n6ORK/8TXGqf4yLfY7y0oh5fV5jP94UiFdkFnUNsz8sH/IN83vrZyN1nGsnhjL4NAnXrPk8B8TfV1P/aLJxIYV1Op2nhdmpMzdK0zQeCZniimuoYuaYh6mxtqk05YnpFaZt6qTanbTF7rY4yiufKzUpczjopaOf3UGNd+eRQK92KdfVxf6tuHTCqf+QEM0mnukhpplZR6dymMrtNY1bTmGjgynsXlNNxDHtHMvBFnTxR4gynDjZH/uswprqhN1N4aVdTMkz9R2nxUgzyKuUNM0dbcJWdOofrbENiIuC/cuXL69Zx7h++/qNJ2cqT7erXmypN3Viarbp/EK58fyFvdFO6pVGcabkjVzKc5DqHPOVSxna2qtfH+vHIsZjB0sd1Cb0qRdffLFOQh2Io8ySQ52oz45Yl8koiwcYw6bkU6bVsezU8Thty9++bG/7Y5TivZ1lAgvJI3RdTGA+CKSf4KRi0kUzjzywZZRKUxscI9ztMr2hdE13v+mp/VkH00OMcjAdQDlMDbFNJ/usi7t63eUyjE6ctroLJKxtOin9E7Yuh3Tpif5ZLzZzrPI0HYHN6NIUlezARtLzwWaNxhKuurIlHLvQQTqN4nHMvvSKGVvi0Et8nArKhqYvRmFkJ2kphzCmEshXlk8dNFqCfRJ0NLUFOrA5CmGIyoBjk1AWcbQR+01CeByd4Rg7xImy+Ii1juFB3dBNWtlE3WGrdNJNOumI7aV2gS1lKx88+kksV2nFlmP6MTrhVIr6KXHURX2sTIcdlCMhLf1UfYtj0lBvRFzYwoF05KdvIOxTZ/UrlSsOpIGTODDNJ4l8YrjitY3pKAf2iH7X6Ma+Ji6kIz62ofolerBT8dSFMNlKXCnkJVw8sA2BV7SHOmMP9oolW+kUw162R26URx7S0z6yGZ2a5pXdaoNs2Jh/Tb4ajHllbL4JzAcBTgRROEkxhI7E6T6dvDjRcOJDcCpI0yRpBCifhIjjZKTpW00RkTfqIh22EC6b4gWN+FI4YeoEffXVV+cLDmkIV3nEc4xQB9IhhKscttKDTUoTw6kzcdSFcDFAF8fEIegRK8IRTrximgPCF2UpPcHsE6Zy2CLoR7e2XFxhjNAGKisHhC/CpUPBMS12ccwn1om0yttLf7RDedhip5ioLmpblUN9mCJTPPkiD4VTPnnQB0vZRXp4Ea60xCs98b1EeWKa2H7owj7Kg7X6FOllO/swVF05joITqDhxVLlskZiGcnrxwR7KRthKNxzQL7uwHdFvQWWKj5zTnCh8URccCHSp/tiDXnQpHDtVdsied2NfUt3U9qozOqkLgh715RwQvig32qO2py3QLXvEhXjyIGzhgqBD4ZTXZntMJ2ayGV3owHbshQ/HlLlQZCQetpmAWkxgbAikO7Uptmr6jW06cU6KTyeuioe7MgW0a9eu1ukjpiIkTAPt2LEjPyuMf3ki5fSM0raFKz5uSZtOhjmIaRdsYlqF9z9qSo34fffdt37avsJVLz2zTHrSSTFP4fDUf2TLli1ZL+k05Ua4HoDLPqL8bPW4k3QHm6exXnrppeq88877LWHxzXQFfCS8Nio+1FZx6eSek1AX5PTTT8/TldjJFFMaWcjh0/3i1U7pzrpKzlBuV5XH9B3C9pFHHqn38074OvHEE7MdPKsOPtQZYSqMtkAfb0ZA1LYqgzaI7wglDTx4JApCunRxmtTH9O9i7KK9KZdyVq1alfNceumlefpRZebAIb+YRmOaKV1Esw30XfWXN954I0+fUg7Txh999FFjKTwzEFsR2kntyDHh5EeXhN9c5KPpLPJRV47RidDX6K8S8sKCaV3eRIFu+gt54ANv3kTB9Gzbw46pC/rRRf31e8FW3n2qcPpNW52xJ9aB4+3bt+epYYXTz7GLOiHobZO//vWvdblKg1233nprZkqbo0tv7FDd6I8qj34DG5jQN/k0ic4LMU469FozWGAvjNHJOZSwhSB7LYRKuA4mMJ8EyhdGN5Ud1ytwQsGxwEni5NX2LkfWAemiycWOJ+dzck53jk1FTDss2hQzc7Isn1fGBYQLQhSdGMu0SiNHCGeFtDfddFN+xIfi2/IR/+uvv+Zkr7zySn690V133ZVfw9R04mZNTFxThK3iprK0pc7EI2y5iHJRx+nShTVHDvjFBQCd1IU24q0FrL/i4sNFId3d50eiwJSLCxeNUriwkI4+QV3kAJGOiznc+WBrdCCkh35SysqVK8ugKcfYBKfjjjuu2rhxY+aRRieyY89z+dS+UzIOEYAunJU0SpPf/4mKrVu31mw45kHKTX0SHtgJT9oJWyXUgc+RRx5ZO+GKK7ekk8PRq++Rj8fVSDd80qhJ5vPOO+/kV4L149OknzrEcHSqn5e2Nh3z9oz4G6T/IqpTPmj5+vnnn6fEwBpu6vvYw6vNaCv6ML+16EShQEzUH6co7ROgGyuSUb70nXrqqVNuBvqoGtnovUfWMhtmAmNIQBcF7vIkhHHRZ+SHu0FOVE1CHjkNXEC4CJFeOss8XNCnI7pzRR/7bLmL5mKNQxCFk10pXPAR3XliKydXttypczJG0hD+pJM/dekn0ok+nEw+2Air0jaYUHfsRuJ+UznURU4XFw6cUy5wDz/8cFPyHIZO1Sfy57VPOEC0JRIvctgaF1VzB68RqZw4fFEH7GKkRbqIpt6qV0g+aTf2LUVEBmpfxWkbR2AUJpa0LaNGbAnrJ2p70kU+6g/KT12oI2moL6NkEh6gDLOmmwraiX5D/4QPjiPcm+qADkZ7m0ROaLQ37isPdsZ2UDh9EDumy0f56WcS6qJ+rrBeW/qsXkFGOtoYoV82Oec5sscXbwaBB/VBcJwoQ/2cvo3omP0m3oQPKvrdkX6Qvj2o3lFKt9coGWNbTGDcCWhKLo4WcCLkxMRFleH0thMpF0fdqZLmhhtuyFNgvBhbwkmQqUEuHBs2bMjBGgFSGu5UKatJcHB4oTXx6NW0CBdQbOR9kWzXr18/Jbsu3pwY0cOoGtMA3FUy9YhwMeLiSDgjCqUDNEVpCODixt02tlFHymPqqxTK0HstKYcRL8JKgQPtwVSlhBP5L7/8ki8m8QSveLZp/UbWiR184JQW5OYkXKy5GDE1ycWIOtJWtAtOgi7aJCaOOuiilRX8/kUZXAiJ14gY3OFFnag/Dkm8k1d+tYOOqTvp6RPYe9hhh+ULrvoFerEx2kw52EUZ5JVORsIokzy6aKsctoyiUUfanvJoB/Vv4mFNXk3l0tfIgyOlaUvSIfS5NieTqVy9pxSnDh38pigPu5naoq5I2++JOOqHvdddd13ORx76axR0MzqDXurMMVtxIDzyiXnZF3/SYR9cENr4qaeeysfwoGx0Dyr8FihXdWZ0NvYvbKTMJuG3VApti0Q7NapFHeiP/K4ltBc2k54t/blNmsojrfoQedEBU/hMh0NbmSMTvlAWd7keJjBfBFgYHCXdreXFmgrjGNGWffKkE9VEOrFy2CgsEGYxKcICTNKzEJQFocQRhhCW7tSzTha1Ek68JJ0IWxedSi9pyCtReLogTdKF3SxElcRysAMbSx7UMda1tA9d6Il6xYUFqdQNOyI/la8tZaaRifxR+WU55Icd8WwlZd0VHrfSn07Uk3iQBl3pYpYXx7KlHnzgUQr11CLbMo70sQ2IJz1lxvoTpn7BVscwlmBvmY/6Sz/2yWbyib3KI6/agHywjcxUDtuoq+RDG9B+hPNhH6Ec6c8B6Yu6KF5h2lIGDGQ/4dhFGHpjHdAR+WA7x+IT7SVO7UE/kEQOykcc+6pLab/yxnTYRxnqk7Sx8hMOnyYhjewir2ygzsqvvkb+GF7qI075iVOdxRR96Ip20taExzbHHtIQLh1lWRyrjkrDVoId2FP2i14slXdctkswNEGymIAJmMCCJsBdMCNvjFyxwJdRCkuVF/XHtTvTYcJo17B5p1NOl2kZrWF9UtvIpWxjNGbZsmVTeBD+9ddfDz36AmONiqkstozyMHI9nVGdNl1Rb7nPSBSji70EW5ID2fc3RT1Yh9WPZa+yRi3OTtSotYjtMQETmBMCXAhYB5LusPteFObEACs1ARNYcATsRC24JnWFTMAETMAETMAE5oPAXvNRiMswARMwARMwARMwgYVGwE7UQmtR18cETMAETMAETGBeCNiJmhfMLsQETMAETMAETGChEbATtdBa1PWZMwL8A4WHBurZJ/xrhWee8NGDKOes8BFWHHlgpp6T02SyeDXFzTRM7TNTPc5vAiZgAoMSsBM1KCmnW/QEeEAhD2/ktSYIDy/kwYh8eA8bfzVue+jcQoWHI6kHavJqDPZ52GYTBx4aSLycrtlgQvk8LBLhtSLxCc850F8mYAImMIcE9p5D3VZtAguKAH+P5/Umei8V7/6Kj1njL/RcxJteH7GgQITKxNdaEHz99dfnkaimZzDxjBrim17zEVROa5enLKcHB+Y85QuOp6XIiU3ABExgCAIeiRoCmrMsPgKaomLarnQcRINRFl4JIiEPozJ84ugLU4IasWEkRaKprraRHNLhoBEve5QXx4Tw6MAxGqTwON0Y02hKki1pGFWL8byqoSwPvaShDlFvegJ0fk2FnBrZxhZ7cXjgwz4MYl5xYCs+2B5HtCgTW5QPPeyz5aO8Kle2S7fs4Bg92G8xARMwgRkRGJdHq9tOE+iawLvvvptfX8AWST+8SSZ9//33OYzXJfCqgxUrVuRXIvBaBPZ5FcUnn3ySX13BKycUTlrlRSevSiBdKVdeeWXOm97jlrfJIclJdKz4Rx99NIend1/l1ztQFnopB9vYZ4vw+gXKY0v44YcfntMRRz506LUOykM4r7eIW9JjM693aLKdV1nAgNdNYDdl8pGgC/2Uj27VBbsQ1TFNm2Y7n3vuuWwnadGrOrCFJeWgC73E6zUcqiN6CZf+XIi/TMAETGCaBDydl86qFhMYhIBer9A0VUX++PoLRlF42bBGOxi94mWrRxxxRP5odIRRG0ZYNHqTHJY8GtRkj179oDVASvP4449X6b1YFW+c5+WzxO+33375VRMaycEeROUob7l9++2386sbsI/py+QU1a9yYCQJ+wlXeYwAMXqF8MLUNoED+ZKTkz/pHV1TkjIdit3/+te/Kl46y8uHpTvWEV6wJj0jUbxYlVEnPgiceBmwbEcH06xqC/iQFyGdxQRMwASGJWAnalhyzmcCPQjw9vX4fiicFy7YXPBxdiSk2bZtWz1FeMkllyhqypY1P5deeml+m/opp5xSbdiwoXbccJ4kafQl70aHCccDwcFAmhweHJzSQWTaCyHfqaeemm1Ff6xDTjDA17777ts3Fe/fwoGKgqPGG+VVphxC0uDUldOrOIDYqLrgjNEeFhMwAROYbQJeEzXbRK1v0RLgYo9olGM6IHAekIMPPrg121lnnZXXCOFAMbLCi3QlaQQ6L3Jnq1EuxcUti7sRXqg6iKQpwKyPfOzPRHiRaz8pHSKlj6N8CmPLQv8mkQNFnOqsUbmm9A4zARMwgWEI2IkahprzmEADAaaNrr766hyzdu3avNhZyRiFIgxniYXTEhwvRoA0atXmRJCetFp0zchSuVidNMRrCixOVZE3ThuSFmkrT07db6l+e2M8OqhD1BvrorSDbmNe2aFt1AEfylR67FAdm0aYYEkaOU3SGR2rqJ990mrBehnnYxMwARNoI+DpvDYyDjeBPgTSwuTs/OBwsN4nLYau/9l2++23VxdeeGHt6DAakhY3V8uWLcsXeNZXMbrCNNkbb7xRj5asXLmytVTSsa7nhBNOqFhTdOedd+a0aXF0tWbNmrzeCWfjxhtvzI7Zli1bsn1Lly7N66MYScKRYJqPUSxswm7yI3H6D0eE9VnHHXdcnvpjFOmuu+7KU2rr16+v9ZBf04dZyYBf6Oa5UkxR8nwn7MaRKUfiNAJFmdSRur/wwgtVWjyfS6Js6kJ+7KctGKkjnOnHI488snrllVcy+16mXXfdddVLL71UO1690jrOBEzABERgCQvRdeCtCZjA4AQYCeLizYW7aQoPpwAn45BDDpmyzocpN0ZI4todRlq07qfNCkZYkFIneVlbVYYrPaM5URSO48E6LR4iumfPninly07SabQMPeSn/izmZhvjYjlxn3RxTRgjP4wkMbq1e/furKPUFY8ZSaOOd9999yQ7sQG9p5122iT9jFbBH4dN7YPdYkH7MB3IGizVU3HRbu+bgAmYQBsBO1FtZBxuAiZgAiZgAiZgAj0IeE1UDziOMgETMAETMAETMIE2Anai2sg43ARMwARMwARMwAR6ELAT1QOOo0zABEzABEzABEygjYCdqDYyDjcBEzABEzABEzCBHgTsRPWA4ygTMAETMAETMAETaCNgJ6qNjMNNwARMwARMwARMoAcBO1E94DjKBEzABEzABEzABNoI2IlqI+NwEzABEzABEzABE+hBwE5UDziOMgETMAETMAETMIE2Anai2sg43ARMwARMwARMwAR6ELAT1QOOo0zABEzABEzABEygjYCdqDYyDjcBEzABEzABEzCBHgTsRPWA4ygTMAETMAETMAETaCNgJ6qNjMNNwARMwARMwARMoAcBO1E94DjKBEzABEzABEzABNoI2IlqI+NwEwgE3nrrreqcc86p7rnnnhDaf/eLL76oTj755GrJkiXVoYceWj377LM502uvvVZdc801/RX0SYFd999/f59Uk6Mpe7r1mKxh8hE2qF4x5ttvv83MYtgw+7PFCt5zYecHH3wwK/Uchs185VFbUteZCPzb+it9krYeVtDd1L7D6ov5ZqKbfjeTekU7Bt2nnXqdX2jPXvGDljOddJw/+/Wf0m7ycN4cZbETNcqtY9tGhsANN9xQvfLKK9W2bdsGtumHH36o1qxZU+2///7VzTffXJ1xxhnVJZdckk8knFR37NgxsK62hOgY5MJBmrPOOiuroezp1KOtbIW//PLL1RtvvKHDevvzzz9XRx11VH087A72UsZM5YgjjqgOOOCAKWo+/PDDgRhOyfh7wF133VVxUVrIIkbffffdjKoJ//32269Rxx133FHR1sMKfbzfRXpY3fTvQX5nTfrvvffeGdWrSWe/sO3bt1eU2ya0Z6/4tnwzCYdfv/5D3/jyyy9zMbfcckv10UcfVRs3bpxJsXOed+85L8EFmMACIMDJnR81J59B5amnnsonjQcffLA68MADczZO8ps2bcrOhcIG1deUbjo6cOrmQpYvX954cly1alVmNhtlnnbaaTNWc/nll89YR5OCxx9/vPr888+bohZMmJxhRlVnIr3y94qbSZmzkffXX38dWA0js8cff/zA6eciYZujOhdlzaZOzhnPPPNMVsm5lhs/zrujLB6JGuXWsW1jTYC7rrPPPrt2oKgMUxmEIZxsjz766DzVFy8g3LHhHDEFGC/8DL8TxqdpKB5Hr2noG8eNYfHXX3895+XkFMuOJyn20U/5ve68iSMd9rOvER7yy07s4WJC+dGueCw96JIdMEIHTNii5+qrr87MVEfSU6c2QQdp+IgV6TWVRLlNjJl+VZuw7Sfopj1j/ZSHsqkDW3ShW4IthGODwtnKJvTBCaHOpOVDeRr1iuxUR8Iok/ykj9O2sc6yq5c96KBN0PPAAw9Ua9euVfJsB+G0L/Y1CeGyQ3ZjAx+EepAfPWV/i3Xu1c6yj/z0aUlsx5Kx2jeWiX2UozpLj7bq3xyXulUf4uB6wgkn5Dop/JBDDql/H8Q31QfbsUe8ZAds+MR2VNtF+ymb8ggjPVzUXuhSn9Fvi/RRYn+U3TGe/dhe6FS7UxbtGMsmPfGqD3GDCH0eXdiJHdxwomOkZcJiAiYwEIE0JTeRLpgDpSXRSSedNJHuqhrTp6H0iXRimGD76quvTqxYsSJvP/nkkzqcvIcffngOJw3pn3vuuawzndQn3n333bx/5ZVXTuzcubNOWxb4/fffT1x22WUTq1evzrqoB/nRhV7K/uabb7Iu0lAudpEGe0qhLPJs3rx54tFHH83p0Ilgo+otmymfcI4RdKeRjaxbDCgTnehGF+FnnnlmPs6Zfv8ijHhspxwYNAn5VQ/KwgbajrzUlbpdcMEF2SbqTHoEnZSBrYT3am+1leoV7VAcurADXdiBoJNyyIcNCieMY9KTBrYIfQDWsc7UgXDqQzrsZ0s+OKJD4TCFE2nU5sqL/tg3oj2kly7SSUiPzdhP+bRnk1Af7CGeLTawpb8i5EUPtrJPeWypG+VSjurAthTyka7sh2X70gZiTPm0BXkIp0zainD2KZPjUrCLNAi61H7SQf8iDbrVrvQxBL2EiTP2lUJdVH/Skle64EccIvsjM9JjM2lgyzF5ZS/h2IeoHqSRzja7c4bwRd+g3vQh8tCHEMKwlzaCK22CEE8cZZGX8tjvJcSTjvqQF77031GWvZPBFhMwgXkmsHLlyoo71KuuuiqXfOyxx+YpMa0ZIB5ZlYa3GQVIJ+484qF1TekEmeN37dpVPf3009W///3vvHaAu9RSWJNFOHd5bLlDZCtdlK272iOPPDJnp3xs+fTTT7MNUScjWaeeemo9Svbf//632r17d53kiSeeyHePuvulfOxVuW+++Wa2lXUb3C2rrmwfeeSRiulBwp9//vlap3aYkqQs7vZlv+LKLXwpV4wVz4gcdbvzzjtzve+7775q3bp1OZq4dCHI8ejnTrhNWAuFnbAs5aeffspBmspNF5m6jHQBzHGMPjDtoiniPXv2VKwjw2a1LwlJQxz2qM7cpROu0TLsoK0Q6qv8F110UdZP+aRRfvqV8r744ovV9ddfn+tMONOTaruHHnqo1pWVpy/Y0QboZBSil6iPqw04pn0R+gP5VV+te6MN6AviGusWy4LBhg0b6n740ksv5Wi172OPPZaP+e0cdNBBuTzypAt11s0oL6McW7ZsyemwQyOVOaDhi98Q7ZUu7JkfNjLy89577+V1e/QlwvhoZAz7KZffMWW3jcokp6HmSX7sYRsl2k88zNBLXthSPnLTTTfVI34c8xtsE35zrDuiXWl/tpSD/ijiCYP/+7//qz777LMcTX1gqfRXXHFFDqcv08YI9aBfDSrYgV7aTv100LzznW6v+S7Q5ZnAYiHAiUAnEdUZJ4ALFBdZFjqX8tVXX+UgTuY6oXOCJB8XrSbhpIeusqymtIQ1nVCV9+23387lUjblUodSOMFycpNouJ16pTvgevhdzgHp0l147RSxQP+8887LTt3HH39cl0f9WHyPSGc+CF9cJFhMj7PHFETbOq90t1xdfPHF2f44JRpUTbmYyQmhftQfJrowxHzsU1fWvD388MNlVD7WiZ8LCaKLITr5wJU/K8jZIs0LL7yQ9XJRJj0XZgRbcHRoN+qiOtNXiOOzzz77ZJ05Q/FFHSiPPxPAj/TUVW3IQl6cJcKxjXZftmxZ1nLKKacU2qrsZDLlcswxx0yys0yIg8RFHrvVVlo0TFqcncg3tjl9B3tuvfXWnnVr+01EW+S0qH3VFqShHvx+EPHIBy1fSqv2jfnKP2ugG6Ft6CvYqjbNEX2+Yt+ISWlLiZhhl8ojbhAu0kGbcMMS27+JBbZT79NPPz079covh1vHbMtzRIzrt99Udr88XcZ7JKpL+i57QRPgZMddHicnCXeInPA4UTC6UMrSpUvzHSUXsyhckKJTEuPQRXpOcNz9xpNpTKd9jfzomK0uDhdeeGF9Nxzj4z4XPk6SpXCxanLQSMeF6/3338/5NPKlcI3MSF9Zd4WzJS/xnLj55yNOAWxK0agNaRllihfrMq2OdXGiveJFUvFxyz/JGI3rl44LN3p1oeHi9re//S2P/OAQYZ/u0OHHMWturr322uq2227Li2xhRzgjAOSlvUkrFtEujcbEMPqERn8YBUQYVYi2w5FySvnll1/KoFy22gzniNEgbCsFfYTLbsqIAgvqKkcgxuHIUefZELFX+6JXdaV8yhpUmpyTOAqr31HUp9FNfu84qxqVi2ma9uX0lXHqU4S38Svz9Dtua/+YD7sZsdL6O0bA2oTRt6bfZVv6GB55xvBR3d9rVA2zXSYwagQ4QXLSioIz0TbSwYWbuzw5UeQlPcPuSLxz1cmXCxt5dAHhRMRJi5M3F0MuCDpx6iSlEzsXBp3goo3lftMFjzSc+FQu5XBxa0qL/aTDDtINUib6uVhx0dXIAPbCQ2VQnybnjLwS+FAuOsRRcdrCiXKQprta6omoXcSRMHTKBurYdIHH3rROJT+2gjy9RDy54KBb7SsGKgsd2KwysVEXf8KpM3nRQV9hi1NNuPKqPjkgfNGfVA486JfqMySjLMVTZnTCmxx32lsLnVnwr74bisy7/C6i3WU8tuAsItQbG7CrrBtlNdVNdlMGdtPuiNpXdcKJQehv6KYshC2/Qbj2E3FQWulGB3yxm3I5Rtgyoqg2JB/cYCV2OeE0v6L96MZ+2lO/JZUX+7TsYat6xGLJr/qQnz4vljEdefV76PebJx3ppUf60Ud7tZ0ziYfnWMkoL9iybSYwKgTSiSYveEw/7onkDNRmEa6FlHVg2GEBJvHpgpHzk5eFpSwWTSfeOiXhLBZFWIBKOeQhLwsrWRhKGhZrko99Fl+SRwt1tXi4abE1OmQ7izyxW4Iu4rGLBanop1zCtSBVabXVQlHVjXqig4WgEtmjYy2QjYuEyYddlEnZ2EAYnyZRueLQVFfVA72qM/WgztiAsABW8dRBbcHCVh2zJV0p8KZtegnloR8d2qIbiWXDmHiEOssmtizgRVRnwiiXdm8KhwV9J7KjXpSLLvJTHh/4KR3txrH6m8JJr7Jygb9/Ea/2Ik1sz5hOdqtPyb7YX9GDDjGXLuXFLtI0tTNloZv8fLBftsMYndSVrdiz5Zi05IEXEvtGDii+sEdp+c1FHSoTjoTLHoWrDVBJ3TkuBZ3YKiGN+io2oxOJZVNWzMN+tEu/ccLVvughPOqMTEqdsoetbIe5+BHObx67JOhA9HunfDGhHUmr+iiPttgiPtgphoofxe1vLTOKltkmExgxAvz4+XCRlqTnA006VnjccnIlX5pKicE99ymDPKVwkumlp1dcv7wqCx3Y3E8GTddPj/j0S6d4ym1io3htSUed26RXuWU7Rx1cANDdSyiXdGxJG/sM+SibvlOK2r2M4xhdpbSFl+m4IN199911MLrKC1mvOtcZww7pSztDdN7t1wYkait30Lq15RfL0iaFl21Sput1LB3l76QtPOpq6zuD2qMymvoDYU36B2kr0jTpLG3vlybWA1vQG4V2laMUw7Xfr08p3ahsl2BI+jFZTMAETMAE+hBgGoLpPE3btCVn3cqf/vSnKt1557VLbenmK5w1L0y9pVGD/M83/pHGGqF+9Zgv+1zO4iHA1B5PgC/XyI0rATtR49pyttsETMAEpkGA9Slab5JGAvI6mmlkd1ITMIEGAnaiGqA4yARMwARMwARMwAT6EfC/8/oRcrwJmIAJmIAJmIAJNBCwE9UAxUEmYAImYAImYAIm0I+Anah+hBxvAiZgAiZgAiZgAg0E7EQ1QHGQCZjA/BLg4X3lAwJn2wIefqgHe8aH/02nHBZn60GePJhQD7skXA8inI6+QdPCZ1ib+5URufRLG+NhKRYxfK73eRio2rGpLGzSQx6b4pvC4AuH6eaLutBR/tuRPq0+whbbKIe+UqblgaLE96pbLK/fPnVp+k3xsM9+fQk79ODOfuUs9ng7UYu9B7j+JjACBPSvsbk0JT2AMf+9nwsIF4lhhHcUnnvuuTkrTyHXE7exfy7rgO7Zurg21bvtqeNNaRVGnn4XY6WdzS1P6e5lLzZNpy14J1x6MGSVHvTZ+D7LQW1Hh95rqDw4SnozAa8p4jU66TlL+R2RvJootikvtMb2rVu3KvuMtjAoHTUU8i4//p3ZS7Cj6enmvfIs1jg7UYu15V1vE1hkBHjGE+/208jAMHfavK6Fix/SdiGfyWhGrybh1R7zIfCJF3eVSXjTRVnx/bZx5I60XKjVFspLGsJLaQsv0zUdU5cmnUq7a9euvLt+/fr6lUT96trWd9peMAw3+suDDz6YHy3BqBPvHNy0aVMum/I+++yzKj0QtX5Rt+ybjW1sT34Hc9mXGGlbVDIqT/20HSawEAmkBxzm1yykk0p+QrReY8BTfdO7tnIYWz3ll6cBp/dj5XC2TeGk11N92eoVDHrNAxx5SjBPBaZclUk4T61WuF5pQjzhlMerLdAfn8Ss10SQv03QoTKpM6LXm1CenlocecTw+IqHyCYyiHWNr7sgXHWK4aWtsJBNao/y6c6E64nMsBBTlUF6wqiPdKgeHKstCGuSWLdYVlNavS5DdRNDWKts2koSbYKb2pB9bG4rL4aXutX/om71PziRF4l8ZI+21AMbZLPqxTHh5EViGXBUuHSTXnwpmzqpD1NX2cJWrOhvHPOh3CZRPFvaV/VSuHRRnsqHUymkV1rFUSZhcCRe9ipeW9KQlvJJ1ySkgZeEY7U/+7KXNJRHGH1H7BUeucW6Kh796CIOiX1Cv23CsZd06v+EIW32/xa78L6bW2vh1dM1MoFOCHDC4l1TnJA4geq9UrxvipMQ4Wz1zjn2+fCuM7Z6zxg6FM6JnA/ChZ686CEtW4QTGSc/TqTSzXvQOOHxfjLCsYWLD3pJjy7ScMy7whDedUUc4b1EOihLJ3D0U45OwuiAh8L1bi1sJpx0CGWjj2O2sh/biUMnPODJO+piOO8Ia7pQ6V12cKUs8ZGTkAtOXyqXY8ogHXnRSRxlsyUfW9oBnYRLJ/XBDsJKoU7Kwz7pmoS4khPl0F6EYw/H1J20COHsUz62wQrBLunKAcUX8eSRbuxu061w+gp5yEu7Yof6aqE+24I9pMM+2aI2QZf6GX0Cverv6IIX+Qknv+yNfYY4whG21KHUCeumvsHvgTzUDSEd5aAT24jDdrZ8mnSQjzjsj4Ld6gfopO7UR781pSUd8QjlK08O+P1L9WGL0L7oQciDXdiMfnSho2RNfORGPtISjg2xzxCGDtKwr98r5ZOHNiKcfT4SOCwmWVy1XUwt67qOBAFOKE0nGMK5q+MkpbtlDCZcd+CqAMeEk5aPnADi2efkV+YhvU6w0qMtF0uViT7yxztMwrgoItiuu13lb9piR0wnu2Qz9nCSJzzyIA/HZThlcIImHvvQgw45PdqSJrIhLbpKIT3pSC9dZRqOGZFDB0J65ZF95FW87CZtqZM0hLVJbIOmNOKiONWRdor1k72UxcVTwoiG2pC82NomqmOpW3UtdUuP2FMuOtokspBOpSWf2DISIpFuOMk+4mI7Kh/hSs8+6SmHOqOT3wF1g0dkR1ok5iWfuP0W+4c+2qTtN0VayiJ/lFh3wrEfW0hLOfrdigP54dlkJ/nJp7YkP+0sm9V+pFG5bCXiGLmVdW1KK3vIhw7K14h2WV/yk2YxiddEpRa3mMBcEliV3lHWJC+//HLF2ogdO3ZU6Q6wTlL+y2v37t05jrR8WI+RTmg5LDkmFfpZtMo6B619SBeGvM/6hAsvvDCnZdErC6pPP/30avny5VW6w8zhfPGPJwm6991337z+5fnnn6/411E/wabzzjtvUjLeHyeb08m8OvHEEyfFc1DWlbDHHnssr03hn0VlPGuSEG3zQfpSORynk76C622Zvo4odk477bSKdS3ow2Z0ccyaGq2FKrK0HqotYgJ0HX300Xk9zJ49e2LUpH0WI8d1K7TJTz/9lBdMx/pFPumCWOugPeOarairTpR24hoeFiJH3TFd1B3D2f/qq69yEO09E4l9UHq2b9+ed4899ti8HbQdlR/GtAO/MepGm/aTJgbU8eOPP+65IJvf1NKlS3uqx37+HccaKMq544476jVQH330Ue53lNW29mzjxo25zagTv1ExY8E6deR3eMYZZ1RXXXVVox1x4Tt9uqmuZUb6HXopA370Jc4JN954Y/73H+sM+b0sVtl7sVbc9TaB+SLQdnFpusg22cTJGWk6sXJSxulAOLmxUDXdHeZ90nOyxsHihEl5HMueJn1ZUfrC0Tr//PPzRVsOm+LatuUFDuet6S/WbfkVft111+WTMuWySPuGG25QVOu2V11aMzVE4OCsXLmyuuKKK6p0x50dHv2Tjwu5FiE3ZJ0ShK5SuLjhqHEhRfiHX5Ok0YTcXrSpRO0WnSPas0nawsu0ck4Ip8you0zbdszLZC+++OKKf5fN5GLaZDOLvREcCy7W0xX+TTndvtH0rzT6RD82tDdOaXS2X3/99er222/Pv4NHHnlk0kJ62payyJNGuerHK2DvunXrst2x/ak7fYff+LJly6rjjjuuxoF95IvStJheDi/p+H2pbysf54iy33IuaGpX+jIffuP8Xliwvhhlr8VYadfZBOaTQHlSomzuAHUh5eKhkxl3/ApnSzijDYTrpMhWIxDE6+SpcrhrJJyt8pb1xTnhBN8mnLwZmYh37tgjG9ryKZwTNGmpm+yQ06hwjtkvLxRcrLiokC+tw8gXL44RlU/9+OhOWid5TuhNI2diFEdU0N8k4ohdOBbIoI5kk74yTDqxv00YYRAnbFe9S67wwU740J76ZyCPXpjigji0AAAHY0lEQVSuzaVuOMJCurEBZmIv20kznb6hfHFLHRh9UzvhXFIujjm8VH/aN4ocG+WLcaVOjpv6RswDA3SqPLVR/B3E9HEfO7GbvPRt8tLfaEsY8XuS/fwuSEcebNeIEvqwE9HvJR/8/qV05FXfx2acMdlMW6icmJd99W2Fx/MN9paOUNknKB974agy4m+KsvVbVBkLfruY5i5dVxOYbwLpBDNpsSkLPREWsxLHcTrJ5GOFc0w48azXiOEs8iRci1tZn0DadELNW6Vn7YbCtTCbBaHkRT9bLRhNF4i6nFzY71/RLoLSCTWvh4hptE8ZKlth6EUHH/ZZSIwOylU49iPYq0W5LFBWPPn4INRZvAhjvQyCDqUnXuE58vcvLcrFBuLFoSmt2oa0CDq19oOtFt+SjnLFEZ0SeKiNFMZWecgnFjFe+6ydoY6kUztq4XPkgw7ZqYW/5MEWLUBGj/alP25Jr/hSNwuqkWg3fQ37yMO+hHLKPkBc7BvEqz8SRx5xoh3VvjBV27DlGDtZzEyZ2EVbKD16xJ942RF1kga7S6Ee5BXHWFfCZR/7xLVJbDO1QUyPHtWDePUjwlRX6aZdFa8wbWkjbFHbEE456ORD/alTE2vC42+NfOiK+dBHGGkRuEm3+hu6VRfaQIzQnZYA5HyL5WsJFU2ALCZgAh0Q4O6RO26NLGECd6nclZfhxJE+ncjYrYU7Vu5E08lu0lohwllPpbtXZeBOUne7Ciu35D3mmGOqdHKv7165U00n6PoOtMzTdExdeLifpvqkg7UdMbzMy4gK05jlnTPpiCvrxAgJa1bK8FKvjrELNk36lWYut/AdpOymuvazCxbi3S/tdOPnUje2oJ91TPH3MF0bRyH9oO07CrbOtg2sw1xMboWdqNnuQdZnAmNOAAeL9TflmiYu+lu2bMkL2YetItMFf/7zn1sXvg6r1/lMwARMoAsCdqK6oO4yTWCECXAX/b///S+PhI2wmTbNBEzABDonYCeq8yawASZgAiZgAiZgAuNIYK9xNNo2m4AJmIAJmIAJmEDXBOxEdd0CLt8ETMAETMAETGAsCdiJGstms9EmYAImYAImYAJdE7AT1XULuHwTMAETMAETMIGxJGAnaiybzUabgAmYgAmYgAl0TcBOVNct4PJNwARMwARMwATGkoCdqLFsNhttAiZgAiZgAibQNQE7UV23gMs3ARMwARMwARMYSwJ2osay2Wy0CZiACZiACZhA1wTsRHXdAi7fBEzABEzABExgLAnYiRrLZrPRJmACJmACJmACXROwE9V1C7h8EzABEzABEzCBsSRgJ2osm81Gm4AJmIAJmIAJdE3ATlTXLeDyTcAETMAETMAExpKAnaixbDYbbQImYAImYAIm0DUBO1Fdt4DLNwETMAETMAETGEsCdqLGstlstAmYgAmYgAmYQNcE7ER13QIu3wRMwARMwARMYCwJ2Ikay2az0SZgAiZgAiZgAl0TsBPVdQu4fBMwARMwARMwgbEkYCdqLJvNRpuACZiACZiACXRNwE5U1y3g8k3ABEzABEzABMaSgJ2osWw2G20CJmACJmACJtA1ATtRXbeAyzcBEzABEzABExhLAnaixrLZbLQJmIAJmIAJmEDXBOxEdd0CLt8ETMAETMAETGAsCdiJGstms9EmYAImYAImYAJdE7AT1XULuHwTMAETMAETMIGxJGAnaiybzUabgAmYgAmYgAl0TcBOVNct4PJNwARMwARMwATGkoCdqLFsNhttAiZgAiZgAibQNQE7UV23gMs3ARMwARMwARMYSwJ2osay2Wy0CZiACZiACZhA1wTsRHXdAi7fBEzABEzABExgLAnYiRrLZrPRJmACJmACJmACXROwE9V1C7h8EzABEzABEzCBsSRgJ2osm81Gm4AJmIAJmIAJdE3ATlTXLeDyTcAETMAETMAExpKAnaixbDYbbQImYAImYAIm0DUBO1Fdt4DLNwETMAETMAETGEsCdqLGstlstAmYgAmYgAmYQNcE7ER13QIu3wRMwARMwARMYCwJ2Ikay2az0SZgAiZgAiZgAl0TsBPVdQu4fBMwARMwARMwgbEkYCdqLJvNRpuACZiACZiACXRNwE5U1y3g8k3ABEzABEzABMaSgJ2osWw2G20CJmACJmACJtA1ATtRXbeAyzcBEzABEzABExhLAnaixrLZbLQJmIAJmIAJmEDXBOxEdd0CLt8ETMAETMAETGAsCdiJGstms9EmYAImYAImYAJdE7AT1XULuHwTMAETMAETMIGxJGAnaiybzUabgAmYgAmYgAl0TcBOVNct4PJNwARMwARMwATGkoCdqLFsNhttAiZgAiZgAibQNQE7UV23gMs3ARMwARMwARMYSwJ2osay2Wy0CZiACZiACZhA1wTsRHXdAi7fBEzABEzABExgLAnYiRrLZrPRJmACJmACJmACXROwE9V1C7h8EzABEzABEzCBsSRgJ2osm81Gm4AJmIAJmIAJdE3ATlTXLeDyTcAETMAETMAExpLA/wPkiD0FeYrvTAAAAABJRU5ErkJgggA=
OK that didn't work !!
it should have been an image or error code 12 unfortunately the forum doesn't let me upload it.
But it says -
Fault code 12 - Wrong door lock module. This fault occurs only USA vehicles. USA vehicles do not have the "door secured" function
1. Check the drivers side / passengers side door lock module and, if necessary, replace it with a lock module for USA vehicles.
It could suggest that perhaps the ECU is coded for US or door lock module is for wrong country.
