1986 3.2
The Central Locking was working ok then one day stopped. It's not the fuse either. It is the Factory fitted Central Locking System. You can hear a faint clicking coming from the Control unit behind the clock, the indicators flash to. If you use the key in the lock you can hear the switches on both doors make a faint click from the contol unit too when you turn the Key, so it's not that! Both Door switches work and the lights come on and you can hear a different relay click much louder. It has a Scorpion Alarm fitted which is how the Central Lock functions. You Press the fob and it the lights flash and you hear the faint clicking from the Central Locking module as before. If you press the Lock button in the Centre Console it lights up Red as Locked then goes off again as it hasn't locked.
Any Ideas? Central Locking Unit? Can't Lock Car as you can't using the Key so has to stay in the Garage
Graham
Graham
